Well my freind and i have just built 2 identical computers we built them at the same time and they all seem to run perfectly fine its just that mine has a slight annoying issue.
First here are the specs
Sony NEC Optiarc 18X DVD±R DVD Burner With 12X DVD-RAM Write Black E-IDE / ATAPI Model 7170A-0B - OEM
XION Solaris XON-403 Black with Green LED Light Steel ATX Mid Tower Computer Case - Retail
BIOSTAR TFORCE TF520-A2 Socket AM2 NVIDIA nForce 520 MCP ATX AMD
XCLIO GOODPOWER 500W ATX 500W Power Supply - Retail
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory
AMD Athlon 64 X2 4000+ Brisbane 2.1GHz Socket AM2 Processor Model
bfg 7800gtx
This issue is that compared to the other identical build mine takes much longer to boot.
When i boot mine up it imedietly stalls on a biostar bios load page (looks like a white background with a big green grass lawn with a raised T in it and biostar across the top. not the bios itself kind of hard to explain what this page looks like. in the bottom corner it says press del to enter setup. If i press delete it will go to the bios.
anyway if u leave it for a good min it will eventually go to windows, or you can press ctr+alt+del and it will go directly to windows.
*another sidenote is it bypasses the entire intialize screen im used to seeing when computers boot up. the one that looks dos based i guess and quickly shows ur bios version, prosseser type, ram, checks something then goes directly to windows...
Please help me : ) Also this might be a software issue if so redirect me please.
** EDIT** pressing delete does take you to the bios
bfg 7800gtx
