the interior layout for the NZXT Rogue (as well as the Raidmax IceCube) is more or less identical to the QPack with the exception of the internal brace above the heat sink fan and a second hard drive cage. Both will fit full size ATX PSUs with a DVD drive in place.
Were you referring to 1200 watt PSUs ? Have you thought about a 5.25" bay PSU to power the crossfire set up mounted under a slim DVD drive?
I also wanted to bring the AOpen G325 / 326 to your attention:
the power supply is mounted to the back of the case like a back pack. Here is the internal layout:
Off track much? He asked about aesthetics. The size comparison is a bit overstated, it's not that massively different unlike many's perceptions.the lanbox is HUGE and the internal design is terrible. I owned one and made the decision to transplant everything into an SG02 when my DVD drive died, just because they are that awful to work on.
So, can we conclude that a case that would be a nice brushed aluminum (or maybe shinny like the TT Lanbox), smaller than the SG02 but with a better layout would be the "perfect" case?
I'm getting ready to move ahead with the prototype and I just want to make sure I'm not forgetting anything when it comes to the exterior design.
I understand what you're going for (I was going to make my own ITX gamer for the same reason, I'm already waiting for the SG-05 to launch). My rig right now comes close to what you want, where we disagree is the choice of cooler.
I have an SG-02 F. It has a 1000W PSU (Ultra X3), Samsung DVD burner (Samsung makes some of the shortest drives), and will be switched over to a GeminII in the next week or two. While not a tower, the GeminII is more than enough to handle an Intel Quad when lined up beneath the PSU's GIANT 135mm fan. The PSU will run ANY video card combination that will physically fit in the case- you don't need a 1200W supply for this. If anything, running a higher card even helps cool the processor here- higher draw from the PSU makes the fan spin faster, which it wouldn't do otherwise.![]()
The GeminII is good. But as I previously mentioned, PSU are rated for around 25C (incoming air temperature).
You are right, the manufacturer only certifies it up to 25C (Link), but I also don't expect to ever come anywhere NEAR 100% of its capacity- especially in a mATX case. That gives me more than enough peace of mind.http://enthusiast.hardocp.com/article.html?art=MTMxNyw1LCxoZW50aHVzaWFzdA== said:Test #4 is equal to approximately 100% of the rated capacity of the X3 1000W at 45c
Agreed, my original project was to be half the length and only fit a 4670- not a 4850. The rest of the design was close enough that I could hack an SG-05 into what I originally wanted.The SG05 - way too big for my taste when it comes to a ITX format. Love the 120mm fan. But not the overall size.
I don't really see what it brings compared to the APEX MI 100. Expect maybe a different look...
