silk186
- Feb 26, 2008
internet and word processing
320 USD
China, I will buy on Taobao
Case, CPU, MB, RAM, PSU, HDD, Blu-Ray, Monitor
None
6) Will you be overclocking?
No
19" 1680x1050
Within a month
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
On board video
I'm planning on using Linux
I want to build two builds, probably identical.
This computer will be used for the internet, Skype and office. I'm thinking about putting Linux on both but I haven't worked with it before, one is for my co-worker and the other is for my grandfather. I'm thinking linux will run faster and be less likely to get viruses.
I want them to be low power and as small as possible without increasing the price.
I'm thinking that it is best to use either an i3 3225 or 3220. One hard drive and use integrated graphics.
Budget is 320 USD,
I'm building it in China, I will buy all of the parts off of Taobao.
I've been doing a bit of research and this is what I came up with:
CPU: Intel i3-3220
MB:ASRock B75M-ITX
RAM: Kingston 2x4 8GB
HDD: Seagate 2TB ST2000DM001
BR: Blu-ray player
PSU: Corsair CX430
CASE: COOLER MASTER Elite 120 Advanced
LCD: 19" LCD
I think that I can also get a second had 64GB SSD from her friend.
What is the smallest case I can get to hold all of this under $50
320 USD
None
No
19" 1680x1050
Within a month
On board video
Budget is 320 USD,
CPU: Intel i3-3220
MB:ASRock B75M-ITX
BR: Blu-ray player
PSU: Corsair CX430
LCD: 19" LCD
