small buget upgrade desperatly needed
willip90
k guys and gals been awile for a upgrade, i want to know your opinion on a few things things here,
Current setup:
Asus A7N8 Deluxe Socket A
Amd 3200+
Radeon 9700pro
Lian Li full tower
Danger Den Watercooling on cpu,chipset,and video card
Enermax 465ve
i know i know why have i waited so long,,, but hey its done made it this far...LOL and im finally convinced to cross the line and jump to the dark side of intel, 600-800 is the budget for a upgrade for now
the upgrade i want is,,
CPU: Core 2 duo 6300 or 6400 and overclock the snot out of it with my water rig
MB: unknown thinking bout the evga 680i or a Bad axe to start with till other 680i's gets all the bugs worked out sli isnt a option now but it might be a future posibility
Memory: a Gig of DDR2 800 for now another gig in a month or so
Video card: probably a XFX 7600gt to get me going till them dx10 cards come out and arent so friggin expensive
PS: was wondering if my 465VE would work for now but i know it will be a future upgrade,,,,
Basically i just want to get my feet wet the rig running and upgrade gradually from month to month till i can get the beast i want like video card the next month and memory the next, if you know what i mean,, i do game and i do like to OC hard... so if you can help me get my feet wet and back onto some scale that is not of the extinct type it is appreciated but i need the basics to get me running with my limited budget, so i can upgrade gradually from month to month ... anyways thanks in advace and sorry for the blurb as im rather depressed with the extinct machine... :(
you might consider a e-4300 with the 9x multi or the e-4400's with the 10x multi when they arrive in April . a gigabyte s-3 or ds-3., asus p5b-e or the biostar t-force 965pt could be a nice budget over clocking mb. most 965p's can do 400-450fsb these days with good ram and a 7x multi e-6300.
the higher multi of the e-4300 or e-4400 will hit higher cpu speed with a lower ram speed . cheaper ram can be used and still get a 3.0g+ oc with ease .
if you want sli a asus p5n-e-sli might be the best pick. i've seen a few hitting 450fsb+ but i think they mostly do around 400fsb which would be more than enough with the e-4300 or 4400's . it does have a small problem with v-droop --however i haven't seen that be a problem when over clocking on air . not a bad mb for $120ish with 8x-8x sli . another nice trick the 650i chipset has is that it can run the ram async--out of step with the cpu buss and it has a extra ram divisor as well .that combined with the extra high 9x multi on a e-4300 should let you tweek the ram and cpu to their max without one limiting the other .
one thing about building a core 2 these days is there are lots of good mb's for under $150. and some decent prices on ram and cpu's to boot.:cool:
I'd get the E6600 since it is the lowest priced with 4mb cache. With the x9 multiplier, you don't need to go nuts with the memory. A decent set of Cas 4 DDR2 800 will do nicely (or one at a time as you mentioned). You can get that P5N-E SLI and you should run out of headroom on your CPU before your motherboard runs out of FSB. Those three parts should run you around $530-550 depending on where you get them. Then use the rest of your money on a new powersupply possibly and a cheap 7600GT.
Do not get the E6600. You can't anyways.
Either get the E6400 or the E4300. They both overclock like crazy.
Yeah... I'd get the:
E6300
P5B-e
2GB of some good DDR2 RAM. That way you save on the CPU so you can buy better RAM and OC the hell out of the CPU.
Just because the CPU costs less doesn't mean you're getting more. If you get a more expensive CPU, you don't need as expensive memory to max out your CPU. Any old DDR2 667/800 will do, so you save yourself there, and you can get by with a cheaper motherboard. If you're getting a E6300, you really need a $270-300 set of memory to max it out and some good luck with your motherboard, not to mention high end air cooling. Where's the savings?
thanks to everyone for you reply's ,, quick question tho would i need a new PS immediatly or would my PS hold up for a month or two with the new rig? thanks willi
You don't think you need good RAM and good cooling for an E6600? If you get some cheapo RAM, and set the FSB to 2.8Ghz, you can run it at stock cooling. How's that?
And if he gets the E4300, he'll have clock for clock the same as E6600 because the multipliers are the same. Its just that he won't have the 4mb of cache but that won't increase performance much. He'll end up saving $140.
The E6600 is a great chip but it's not for budget builds. The E6600 is high end.
Clock for clock the E4300 and E6600 are not the same. I believe Anandtech did a review where the E4300 was clocked to 3.3Ghz or so and was being beat by the X6800 at stock speeds in some applications. My point is really you can save money by going with a higher multiplier, especially on RAM. If you're deciding between an E6300 and E6400, I'd get the E6400 and cheaper memory. Most E6600's will do 3.2-3.4Ghz without too much effort. You're almost spending as much money to get a E6300 to do the same when you factor in higher end memory and motherboards.
E6600 ($300) + cheap DDR2 800 memory ($170 or so AR) = $470
E6300 ($180) + high end DDR2 800 memory ($270) = $450
For the extra $20 I'd take the E6600 with the extra cache.
