Slim 92mm Fans
haffey
I'm thinking of getting the T-Rad2 for my soon to order 4870, but I'm going to need slim 92mm fans if I'm going to go Crossfire in the future. I think a 20mm depth should do it. I used Goggles but can't seem to find many slim fans like this. Does anyone know where I can get some (preferrably with high airflow and low noise).
The only 92x92x20 fans I could find are manfactured by Yate Loon and I couldn't find anywhere to buy them.
I believe Petra's Tech Shop imports their Yate Loons directly from the manfg.
You could try contacting them.
Good Luck!
Good Luck!
Thanks, I did check out Petra's online store shop but I will send them an email or give them a call. I have heard nothing but good things about the Yate Loons, so I will strive to get those.
