freddiepm61
- Oct 19, 2004
Hi,
If I am getting dual 6800 ultras from leadtek, and an OCZ 600w PSU, which power cables should I use?
Of course one of them is a 6 pin pcie connector, and so that is fine.
However as this PSU only has one, does the graphics card come with a converter?
If so what do I attach it to?
It has 2 shielded VGA/HDD cables which I guess you would use for an AGP 6800 ultra.
are these 4 pin molex, and if so is this what I would attach the converter to?
Also, if there are only 2 sata power connectors, and I am getting 3 sata hd, what should I do for powering the 3rd? it is a 200gb western digital caviar...
Anyway, as always thanks for any help
f
f
