Hi, I just found these forums... looks like a good place
I am not up to date on the SLi technology, and I was just wondering what's compatible with it. SLi is nVidia only? (if so is ATI planning on releasing something similar?) and it's not just any PCI-E cards... they have to be specifically designed for SLi? and if the cards are specifically designed for SLi, are they backwards compatible with non SLi motherboards?
edit: also for the power supply, think this would work?
http://www.newegg.com/app/ViewProductDesc.asp?description=17-153-004&depa=1
if not, I'm thinking this would be sufficient:
http://www.newegg.com/app/ViewProductDesc.asp?description=17-103-912&depa=1
