SLI problems with 2x8800ultras
T0pth4t
I recently purchased a 2nd 8800 ultra for my system and I have been having some problems with it first off here are my specs
Microsoft Windows Vista 32-bit
AMD atholon 64 X2 6400+ @ 3.46 ghz
ASUS, CROSSHAIR, nForce 590 SLI mobo
CORSAIR, 4GB (4 x 1GB) XMS2 PC2-6400 DDR2 800MHz CL5 (5-5-5-12)
2xMSI 8800ultra most recent drivers
2x 320 gb WD hard drives in raid 0
ANTEC, Quattro 850 Power Supply, 850W power supply
My 3dmark06 score is identical to the one i ran without dual video cards(12000+/-) and as far as i can see games dont seem to show much if any improvement. crysis gpu-benchmark has actually gone down since I installed the 2nd card. So well is the power supply to under powered? I want to be sure before purchasing a $300+ new power supply. Also is the cpu to much of a bottleneck for this system to show any improvement anyways? thanks
Your PSU is plenty for that config. What drivers are you running?
Even at 3.5Ghz the X2 is probably holding you back with 2 Ultras, though.
I'm using the 169.25 drivers but I'm going to try the beta drivers to see if they make any difference. Yes I did enable SLI I'm not that much of a noob lol. I'm using a 24" monitor 1920x1200. So you really think that its the CPU that is killing it? or should I still at least be seeing some difference with SLI?
Well, if you have the pro version of 3DMark do this -- change resolution to 1920x1200 and disable SLI. Run the test and watch framerate. Then cancel the test, close 3DMark, enable SLI (and make sure it's enabled in the 3dMark profile in the Nvidia control panel too -- I'd recommend Force AFR 2) then start 3DMark and run it again at 1920x1200, watching framerate. You should see a difference.
If you don't have pro, do the same thing with a fairly modern, demanding game like Bioshock, COD4, Crysis, World In Conflict, etc.
...you cant be serious. These CPU bottleneck people are like zombies. Stop eating peoples brains.
edit: this was intended as somewhat of a joke, but apparently I'm mindlessly flaming.
The 8800GTX was released two months after the release of Core 2, everyone was still trying to fathome how the Core 2 actually performed so good. If intel's next gen had been released three months later then it was, a 3.5Ghz Athlon X2 would have been the reccomended component for an 8800GTX SLI system. The 8800GTX and 8800 Ultra differ by single digit percentages.
Careful, read before you start mindlessly flaming.
He asked why his 3DMark score didn't go up. I said it was because of his CPU. I didn't say his gaming performance was going to suck, I said what you quoted in direct response to a question about 3DMark scores (which I put no stock in, I just didn't feel like repeating my usual anti-Futuremark rant this time, and moved on..). Also, don't pretend like framerates wouldn't be higher with a heavily clocked Core2Duo or Quad instead of the X2, because you know they would be. Not a ton, but the difference is there, and it's undeniable.
Some of us do in fact know what the hell we're talking about, and I would've hoped you'd established by now that I am, in fact, among that rare and privileged minority.
wow, I typed out a nice long explaination and its gone because my session expired and I hit the back button T,T.
Anyways, I'll short form: Silent circuit, hard to be careful when I'm mindless, dif between AX2 2.4Ghz and C2Q 3.2GHz at reasonable res and on a non-insane physics engine is un-noticable. So I dont need to pretend, I'll just deny it based on the millions of reviews out there and all the editors of this site to back me up.
back on topic: its your 32bit operating systems fault. the OS has to come up with memory adresses for almost every cache including video ram, not just system ram. As such "GPU 2" has 0MB of cache.
remove two of your 1 Gig sticks or one of your 2 Gig sticks to test this theory. If your score inreases, it means your OS wont support the memory on that 2nd card and you need to upgrade to a 64bit OS.
i don't put much stock in 3dmark, but how much of a difference are we talking about when you enable or disable sli? the last time i used it was with x1900xt cf matched with an x2 4800 in a rd480 board. 3dmark 05 reported only a 1000 point improvement even though i was able to run fear at 1920x1080 with max in-game settings plus 2x adaptive aa. you might want to try a game.
I've installed the beta drivers and I can now see a framerate increase in crysis and in 3dmark06(went from 12264 to 13032) but since 3dmark06 doesnt seem to be much of a bearing on preformance i guess i shouldnt worry to much about it. Do you think if i got the new phenom 9850 my system would be able to live up to its potential? From what I've read so far its only slightly worse than the Q6600. and is switching to 64-bit really worth the hassle meaning will i see that much of a difference between that running 4GBs of ram rather than just running my 32bit OS with 3GBs? thanks for all the help so far!! :)
I've installed the beta drivers and I can now see a framerate increase in crysis but still nothing in 3dmark06 but since 3dmark06 doesnt seem to be much of a bearing on preformance i guess i shouldnt worry to much about it. Do you think if i got the new phenom 9850 my system would be able to live up to its potential? and is switching to 64-bit really worth the hassle meaning will i see that much of a difference between that running 4GBs of ram rather than just running my 32bit OS with 3GBs? thanks for all the help so far!! :)
problem with phenom on am2 is that few manufacturers are releasing bios updates to make this transition possible. there's also the distinct chance that an am2 board will nerf some of the performance of that phenom.
ASUS seems to be good for bios support they have 9600 and 9500 support but what are the disadvantages to running an am2+ on an am2 board
Thing is your OS is physically unable to adress all that memory. Maximum addressable on a 32bit bus = 2^32/1024^3 = 4.00GB. Right click on computer and hit proporties, I betcha it says something like "Memory: 3.2GB". Thats it. Thats all your computer sees, and it doesn't see your 2nd 8800 Ultras cache at all.
So, is it worth the hassle? Umm yes, and anyone in the PC biz would have told you to install the 64bit copy from the get-go.
on an am2 board you loose hyper transport 3, official support for 1066 ram, and a reduction from dual to single processor power planes (only an energy saving feature really).
:confused:
um no?
Both Gigabyte and Asus have CPU voltage regulation throttle, which allows some of the voltage regulation to be shut off when the processor is in idle. Asus calls it their "Energy Processing Unit" and Giga-byte calls it the "Dynamic Energy Saver". Both effectivly do the same thing, but, arguably, Giga-bytes all solid 16phase is higher quality (excessive even). You can read about the two here.
These features are by no means part of any referance board design or referance AMD layout. Both of these (very similar) technologies were brought to us by these companies own intuition.
So is the 32-bit O/Ss inability to adress the ram on the 2nd card what is causing the constant display driver crashes I have been having?
:confused:
um no?
argue with amd then, i'm just passing on their info.
http://www.hardocp.com/image.html?image=MTE5NTQzNTAzNzN1Q25HQmZCSWxfNF82X2wuZ2lm
