SLI drawbacks?
blkaplan
If at some point I am considering getting SLI but not for a atleast a year, are there any drawbacks to having an SLI mobo setup but not utilizing SLI?
Consider some things......
your sli mb will function fine with one card
you should get a power supply that will support fully PCI-e and two cards in sli
the CPU needs to be robust so as not to bottleneck the sli too much
good cooling in the box
a nice monitor that supports high resolution.
:D
Not really, most modern games need maybe 2.2ghz (in AMD) to run at optimal efficiency, even with an SLI setup.
The only times you see CPU limited related issues is if you are playing older games or running at extremely low resolutions. Anyway why the hell would anyone buy two high end video cards to play old games or at low resolutions?
Usually, the SLI boards have the most "robust" features. They are the high end boards even if you don't use SLI.
I wouldnt use a celeron or semperon in an sli. thats what I meant by the cpu, obviously.
why use your old 15 inch crt to team with sli???? thats what i meant.
a 2.2 Ghz AMD would be pretty robust dont you think???? ~3500+ or above, not your "average web browser" cpu.
If you didn't get an SLI mobo yet I recommend you wait a few days for the SLI 16X boards to come out which run a full 16X speed in both PCI-E ports when using SLI rather than the 8X that current SLI boards do. Benchmarks don't show a huge performance increase until you turn on SLI-AA in which case your frame rate is pretty much doubled or more compared to the current SLI boards.
I only saw that happen with FarCry and only with SLI-AA. I'm still not convinced it makes that big of a difference.
No thanks. When it is a single chipset solution then I'll get one. Plus, have you really looked at those benchmarks. You'll find the presentation to be "skewed" in favor of sli 16x.
Nope, check my sig, I'm doing exactly what you are wondering about. In fact, because SLI has been available for a while, and also due to the newer SLI X16 boards beinging to be released, standard SLI motherboards are significantly dropping in price.
With rebates, etc, you should be able to pickup an SLI capable motherboard for less than $100.
Also, SLI boards then to have the extra bells and whistles onboard that the non-SLI boards may not have without purchasing a deluxe or platinum edition.
Every single SLI capble motherboard will also let you use the second PCI-E Graphics slot as an x1 PCI slot if you are not using another graphics card, so the slot is not a complete waste if you "never" go SLI. But you have that capability at any time you wish in the future without having to yet again purchase another motherboard.
Enjoy!
I have seen quotes that say the ABIT 32x board is gonna be like 200 dollars and come out in another month...
boo!
Exactly...why spend $200 when you can get the Abit AN8-SLI for $100 after rebate? I picked one up and it was a solid board while I had it ;).
