Hi,
I have 3 VGA only monitors (LCD 1920x1080). I was running eyefinity off my 5770 and it worked. Now have a 6870....one of the DVI's is digital only, so can I hook up my monitors via analog DVI + 2xminiDP? (Using adapters for each)
I have been searching and searching... Can anyone verify that 2xmDP + 1xDVI-I will work? Diamond MM actually said that it wouldn't.
Mike
ps - yes I was very stupid to buy 3 emachine LCDs with VGA only. : )
pps - but why does the 6xxx series use DVI-D? what advantage does that have over DVI-I - other than no analog signal?
Mike
