Silverstone Tundra TD01
Dark Prodigy
Jawbreaker
An external passive watercooling solution from Silvertone....comments?
Its supposed to come with a cpu block as well...If anything.. it looks good.
.....and where does it expect to radiate the heat off again? If thats all there is to it, it wont cool very well at all.
Looks like from the sides. Won't dissipate a huge amount of heat, but would work for low noise/htpc applications.
It looks cool, anyway. Is there a matching case for the actual computer? That would look pretty sweet.
silverstone = arm + leg.
looks like a sleek unit. don't know how effective it's gonna be tho...
i like the ol' school temp gauge
I personally think that would be the best application for it. And it looks living room worthy.
There is a black version also that looks even better. There has been some tests done, I can post links if anyone is interested.
