Silverstone TJ11 Carbon
kier
Sponsored by:
Hello my friends.
About 4 weeks I was doing nothing, My wife was getting crazy.
But now it is here ......... a new build, with a beautiful case, the Silverstone TJ11
When I first saw the case I had something like "I to want to mod this one"
I must admit that a number points are not so nice at this case.
This "negative" points I will certainly adjust. But they have also a lot of beautifull things renewed.
The main hardware and other materials
De hardware:
Case: Silverstone TJ11
PSU: Coolermaster 1200w
Motherboard: I’m not quite sure, but for the fitting and measuring, gonna use a EVGA Classified E759
Processor: i7 930
GPU: 3 x GTX 480
Memory: 6 x 2GB Corsair DDR3 1600
HDD: 2 x SSD 120GB And some sata
Cooling:
Water cooling of course, but have to gather and brainstorm what best suits the TJ
So it’s a bit of a gray area. But I have some great ideas.
For now:
2 x EK 360 radiator
EK HF Supreme plex
EK Ram cooler plex
BitspowerSilver shiny
Tygon tube Transparant
And more…….
Other products/ materials:
MDPC Sleeve, colors: Black and...........yellow
Carbon fiber film
SMD lighting I think, but not too much this time
Some Acryl, yellow and black
About what exactly will happen, I will not say too much for now. I have a lot of ideas;)
The beginning:
My hero the guy of GLS, delivered the package of highflow.
Luckily, he treats the case with love and the TJ is without damage.
It’s big, really big…………..but beautifull
De Silverstone TJ11
The box
Out of the box
Inside
Top-mounted slide out motherboard tray
9 uninterrupted 5.25” drive bays
9+1 expansion slots
6 x 3.5” hard drive trays
Dual see-through air intake vents
Dual ATX/PS2 PSU compartment
2 x AP121 fans with hot-swap adapters
Extra large motherboard tray cut-out for CPU cooler backplates
And a little box with small stuff
Manual……….lol
Fasteners, unfortunately silver not black. Missed opportunity
SSD Brackets
Horizontal mount bracket for the PSU
Filter
PSU cable
And a Silverstone logo for on the case or something. could laugh about this
Because the painted this on my beautiful expensive case
Do not mind that it’s made in China, but please don’t do this anymore
This was the case step by step. next challenge is to brainstorm how to install the various components.
New case, new challenges I love it :clap: ............... to be continued;)
Grtzzz.
360 radiators are an insult to the case. You need a 480 in there at least.
Also, why get EK blocks when the Aquacomputer Kryos and MIPS RAM block are better.
Off to a good start, Im watching.
Thnx ;)
Maybe........wait and see if they are an insult.
It,s all pure looks my friend, results are at a second place (for me)
Looking great can't wait to see what you do with that amazing case!
So much space to work with there. The possibilities are endless. Cant' wait to see what you decide to do.
Hope you're going for the copper versions because looks are the last thing you're going to have once the nickel versions start peeling.
Wow that is incredibly cheesy to paint "Made in China" on it, even if it's on the back of the case. A sticker would have been sufficient but you'd think that for the price, they wouldn't gaud it up with either. :mad:
Will it come off with alcohol or paint thinner or anything (or have you not tried yet)?
Yeah now that you mention it, The case is expensive and shouldn't have that.
Update: dismantling the TJ
What a pleasure, I didn’t need this today. No rivets in this case
Only used this one
Have almost the entire case apart and this is what’s left
First removed the air intakes what was quiet easy apart from one thing
The speed controllers on top are not with a connector, so had to remove it from the case
Back side with the filters
Hotswaps also removed
These will still be used
The fans from the bays
When this was out, had playtime with some motherboards
Find the board
Small isn’t it, can you see it?
No, not this one......... but for now this one
Still is a nice motherboard with the EK blocks. Maybe it willstay with some changes to the red, but I’m still not sure
Back of the tray. Enough space for swapping the backplate
Enough slots
Continuing the dismantling. The top panel is simply push / click, but it’s a very nice design, therefore some pics;)
Other side
Quick look at how it’s gonna be with a 360 radiator
PSU in..........lots of space :)
Further......still with my Phillips screwdriver, the drive bays. Very easy to disassemble
Had to disconnect the power switch because it is connected to the switch on top
Nice hole can be adjusted
Omg where is the TJ?
Midplate. This was a bit more difficult, I had to remove the motherboard slide
But still managed without too much trouble
It’s huge ……..63 cm
Hmmm, not much left of it
And again placed the 2 radiators inside with the fans on the inside pulling air through the radiators
Like this I have enough space between radiators for the tubes
psu in it. Not the psu that is finally coming in, but I had this one lying around
And some pictures of the color combination
Carbon and black
Yellow sleeve with it
And always nice..........the black one
Looks nice!!!
Just ordered some stuff for the case itself. I will keep you informed ;)
Grtzzz.
Introduce the most sought after full tower with amazing talent right here.....This build will be EPIC!
I do hope so, Idk about the most sought after i hear more people wishing they had a 800D but never the less it is a killer case.
On the subject of killer cases, Hey Kier ill trade you my Khaos for your TJ11 :D
Thank, no compromises for this one
Hmm, let me think about that :D
Update: First carbon practice
3M Di-Noc CARBON FIBER FILM
Yesterday been playing with the carbon film
To test my skills, I have coated my classified block with the film
before
And after
Also my Supreme HF coated. Again before
And now with carbon look
Put everything on the motherboard
Also did the laptop
Just kidding
The waiting is for the materials now, but luckily I have some stock
For the radiators I’m gonna make a sort of bracket, from beginning to end of the case, at least on the visible side
other side gets an open area for cables and other purposes
Piece of iron plate with the angle to cut
Round edge marked
Cutout for the psu
And here the custom plate, perfect fit
Opening made for the radiator, so that you don’t see the mounting holes and just straight to the air intake of the sidepanel
Sidepanel on it
Rear intake is gonna be closed and the whole will be covered with carbon
That’s it for today.
Bye bye
Update: Front plate
Fortunately i’ve received some products this week, modding time !!!
To place some hdd’s put the hdd bays together
To get this build a little over the top I’m gonna put in 3 BP hdd coolers. A while ago I had two from L3p bought for a future build, but this is the perfect case for the coolers. So This week i’ve bought the third. L3p Thanks man!
Later on hdd's underneath with some support at the sides
The bay is accessible and gonna be placed like this
And i’ve used an old piece aluminum panel that I had left after a window cutout ........ never throw something away
Draw some Lines for the jigsaw
After some sawing and filing it already starts to take shape
Adhesive tape over it to see how it is going to be
And tried without tape
After that the slot for the slim-line DVD-RW
And then put the plate on the upper and lower bay cover with
3M Scotch Clear Mounting Tape #4010
And put everything back
But not finished yet ....... missing something.
I ordered some yellow acrylic. Really a gamble because no pictures were there of the yellow color
But fortunately it is just the right color that fits with my yellow sleeve
Made some french fries
And made the yellow lines in the slots of the hotswaps. Don’t have to be open because the water cooling. And the yellow lines will come back more often in this build
And the remaining three hotswaps finished
Imagine the front plate with carbon film (vertical straight lines)
And finally a hardware exchange. The Classified goes out the to a buddy of mine, he was in love with the carbon blocks. And I got an nice opportunity
Rampage III Extreme
With EK full cover block
This will also be covered with carbon;)
That's it............Grtzzz
Nice work so far. Still watching this. Looking forward to seeing more.
Update
Now that I have the REIII I can not stay behind in order to coat it with carbon. Before I'm going to do this, there is some treatment needed.
If I stick the carbon film without doing this, you will see the holes where the bolds are in
That's why I’m gonna cover the holes. What we need:
Detergent
Ammonia with some cotton swabs
And some silicone sealant
First I have cleanedand degreased the holes and bolts
Then the put the sealant in it and smoothed it with detergent on the finger
When everything was dry I put the carbon on. Heated the carbon with the heatgun to get the Straight edges
Cut the edges and lines with a sharp knife
Then it was time to treat the motherboard. Screwed the The original blocks off and used a cleaning kit to clean everything
Arctic Silver ArctiClean Reinigingskit
A few drops
And it's clean
Placed the Waterblock
Finished
I also changed the cover of the radiator, as I need to have optimum heat dissipation. That's why I cut a 120mm hole next to the radiator
This fan will blow the hot air out from the lower compartment
To still stay a little original , I’ve have made a custom midplate, this will be covered with yellow acryl
1mm Aluminum plate
First tape it and marking it
Total shot coming up. The air intakes in the side panels are in my opinion not pretty, but it offers a possibility to use it for 2 aquaero's
Made a bracket and fitted it with an old Aquaero
For this one also created openings for the midplate that still has to be bent. I had hoped that I already could showed, but I'm still waiting for my new little folding machine
Then placed the two Aquaero's VF
Placed the midplate in front
Also placed the side panel
To get smaller recess in the side panel I have a made a piece of aluminum and marked it
And made this also with openings in the size of the display of the aquaero, s
These I put on the inside and on the outside I have made another piece
This I have made as tight as possible because there wil be later on carbon on it and I do not want to have ugly edges visible. Just put a little bit carbon on it to show what the intention is
Soon as I'm going to do the whole panel, and maybe I’m gonna place another acrylic display for it
Am also has been busy with the hardware and the WC stuff. Gonna place the reservoir at the back. For this there are coming 2 x EK-DDC X-RES with 200mm reservoirs
To see how it will look i’ve placed them like this
Fits tightly next to my Corsairs
Placed the two GTX480, third one is coming. Still gonna do someting with the gpu’s
Now there are nickel backplates but these will be exchanged with black ones
Nice to have Corsair
Tuesday my folding machine is coming and I can finish the midplate
That's it on my last day of my vacation, tomorrow back to work ........... unfortunately
Updates will now take a bit longer
Grtzzz.
Looking better and better. I really like the Aquaero's in there like that. Don't see that placement very often.
Small Update:
This week i've got my little hightech folding machine, real nice addition to my tools
Ok, lets bend something,
And the midplate part one
And sawn the midplate part two from the yellow acryl
And put it al together
Everything is gonna be poadercoated later on
And next step is to measure al the slots for the cables and the WC
To be continued ;)
this is amazing.
Love all the custom work. The yellow acrylic looks pretty amazing too.
Can't wait to see more!
Sleeve Update:
Today there's rain in the netherlands, a lot of rain, so a good excuse to go sleeving
For this I'm gonna renovate my Be quiet my 1200w power. This was one of the first PSU I've ever sleeved. And in the meantime, I've learned some things to do a beter sleevejob
Renovation work includes: giving cables the same size, heatshrink equal size, tighten the sleeve on the wires and add a color.
Just a little tip, if you start using a light color sleeve, it is best to use same color electrical tape around the wire as the sleeve color
This is because the color of the wire always stands out. Orange, black etc. you can see the color through the sleeve
Not shocking but "no compromise";)
Yellow sleeve............ yellow insulation tape
Now you see no other color through the yellow
All black heatshrinks renovated
And the wires of the PSU are finished, did also extend the wires for this big case
placed and arranged
Now the modular cables, with the same color scheme
More to come ;)
Update: First cut in the TJ
Hi my modding friends. Did my first cutout in the TJ
For the cpu power, needed to make the hole bigger for the connector
Now it fits trough
Also did some nice things for the midplate. Second cutout in the TJ
There goes the midplate :naughty: second part for the midplate is the aluminium cover
Made some slots for all the cables
Third part is the yellow acryl, also made some slots in it. There's gonna be more, but for now only where the cables goes through
And the last layer......... the black acryl
Still need to do little adjustments to the acryl, but looking good allready
Put some cables through.
Today my next GTX480 was coming in, so placed it. For now without the WC block
EK has given my the third block with some other beautifull stuff, so this one is still coming
So made the last gpu slot
I know, a lot of black and yellow............hope you like it ;
Hopefully my EK products and the MNPC Carbon is coming in this week, to let you show some more great stuff.
Sponsor Update: EKWB
This week I received a very nice package with even beautifull products in from EKWB
The package (always nice to receive packages)
Containing a fine collection of WC stuff
First a nice Coolstream360 radiator.
EK-CoolStream RAD XT (360)
3x EK-FC480 GTX Backplate Black
2x EK DCC Top with 140 reservoir
EK-DCC X-RES 140
The last Block for the GTX480
EK-FC480 GTX
Placed the DCC tops on the MCP355
Instead of 140mm reservoirs I’m gonna useEK-Multioption RES X2 - 250 Basic
Like this
The GPUs will be connected to the front res, need to adjusting the black acrylic to get a straight line to the inlet of the reservoir
The outlet of the pump is going down through the midplate to a draining point, and so on to the radiators
I also have placed the back plates and installed the last block on the GPU's. Always looks nice
And placed everything
EKWB thank you for making this update / build possible
loving the detailed work on your build. nice.
i'm curious about the reference you made regarding the 'hightech folding machine'.
wasn't able to find much on the net. could provide the manufacturers or resellers webpage.
i'm interested in doing a little aluminium work for my case & need something for doing professional shaping / bending.
cheers.
