SilverStone SX650-G Dual EPS
Discussion in 'Power Supplies' started by Klrgoten, Aug 23, 2018.
  1. Klrgoten
    Klrgoten Gawd
    642
    Oct 16, 2012
    Hey all,
    I can't seem to find a SFX / SFX-L psu with dual EPS connectors for a project I'm working on. I currently have a Silverstone SX650-G sitting on a shelf and was wondering if anyone can dumb-check me on potentially using one of the two modular PCIE ports as a secondary EPS.
    I've looked at the pinout of the port and they look identical to the standard EPS port so it should just be a cable that I need to create.
    Possible or stupid idea that will burn down the house.
    Thanks!
  2. Luke M
    Luke M Limp Gawd
    385
    Apr 20, 2016
    On many modular PSUs the PCIe and EPS plugs are interchangeable, so you would just have to buy another EPS cable. However, that doesn't seem to be the case with Silverstone.
    Alternatively, you could use a PCIe->EPS adapter cable...as long as you aren't coming close to using 100% of the maximum EPS power.
  3. dexvx
    dexvx [H]ard|Gawd
    1,100
    Aug 14, 2002
    How do you tell if the modular PCIe and EPS plugs are interchangeable?
    I have a Corsair CX750M on my test bench and would like to test dual EPS12V boards.
  4. Luke M
    Luke M Limp Gawd
    385
    Apr 20, 2016
    If they are labeled the same and use the same connector, that's a big clue.
  5. Tsumi
    Tsumi [H]ardForum Junkie
    13,030
    Mar 18, 2010
    Just use a PCI-E to EPS adapter. That would be foolproof.
  6. Smitty2k1
    Smitty2k1 Gawd
    650
    May 31, 2005
    I don't know for sure but Silverstone uses the same pinout in all their modern PSUs so that all cables/after market cables are compatible.
  7. chx
    chx Gawd
    696
    Jun 21, 2011
    Did anyone manage to solve this problem without resorting to a converter like this? I'd strongly prefer not to :/ It's ridiculous how hard this is -- the Corsair 600W has a uniform pinout for the PCIe and EPS https://smallformfactor.net/wp-content/uploads/Corsair-SF600-pinout.jpg so this would take care of it but it's not SFX-L :/
    Someone with the right molex tool needs to get on creating the right cable... pinout at https://www.modders-inc.com/power-supply-pinout-repository/9/ -- get three 12V lines from the PCIe connector and steal one from the peripheral block.
  8. Tsumi
    13,030
    Mar 18, 2010
    Not enough of a market to do so. Most SFX form factors won't need two EPS. Even if the motherboard supports two EPS, it usually doesn't need both of them to run.
  9. AMv8(1day)
    AMv8(1day) [H]Lite
    125
    Jan 6, 2011
    Well I need it.
    FYI, Corsair is apparently releasing a 750W SFX unit that will support dual EPS sometime soon, probably announced around CES.
    Although depending on timing, I may skip the SFX PSU altogether and just buy the HDPLEX 400W HiFi DC-ATX and 400W AC-DC kit. HDPLEX is perfectly willing to supply multiple PCIe-EPS cables.
    Sometime in the near future, they will be releasing an 800W DC-ATX model that will support dual EPS perfectly fine. You'll just have to shell out for two of the internal 400W bricks and work out a multiple power cord situation.
    Which if you are going through all of that juryrigging hell, finding an extra mount location for a second C13 socket and buying a Y splitter power cable should be trivial.
  10. smarenwolf
    smarenwolf [H]Lite
    94
    May 7, 2018
  11. AMv8(1day)
    AMv8(1day) [H]Lite
    125
    Jan 6, 2011
    Yeah, it wasn't actually made available until about the 2nd week January. Right after my post. I was one of the first people I saw to order it on Jan 7.
    It's been working great in my Cerberus X. Pretty quiet. Cables could be a tiny bit longer though. The Cerberus X is obviously a larger than average SFF/SFX case, but with the placement, the EPS/ATX connecters really couldn't be closer and they still required a ton of effort to get the cables to reach.
    Also, I'd really appreciate some alternative cable options. Longer, low profile, maybe alternate colors? It's a pretty premium PSU designed specifically for high wattage, high dollar systems. You might as well make it pretty.
  12. Smitty2k1
    Smitty2k1 Gawd
    650
    May 31, 2005
    Silverstone does offer a ton of aftermarket cable options and all their PSUs use the same pinout.
