I did a quick post to Silverstone, but linked your original post rather than the whole thread.
http://hardforum.com/showpost.php?p=1038813830&postcount=17
I really like the mock-up, I'd even pay more to have one. Its very clean and sleek but I'm left wondering how we'd handle the PSU power cord.
My only suggestion would be to work fans into the front. This could be done w/mesh grilling or something stylish.
I hope someone at Silverstone notices your work formally. ^_^
There are dual 92mm fans in the front.
Yeah, so Tony got back to me, here's the gist of it: the SG09 aesthetics were polarizing at Computex; my redesign looks similar to what they'd like to do in future models, though this specifically wouldn't fit into their Sugo series on account of the 23 liter size limit for that series (the front panel on my design adds depth, pushing it over the limit).
redesign doesn't change the internals - the power cord is still routed to the back as Silverstone has it. That plastic housing for the outlet protruding from the back is somewhat questionable though, and could probably be improved.
Sorry, poor choice of wording. I know the fans are still under the PSU, it was the airways I was thinking about here. Just not sure how much the side exhausts could do.
I wish you all the best with your future ventures into case design... Or whatever it is that you do. Great job regardless.
I should have been more clear. Doesn't the psu exhaust shroud block the plug for the psu power cord in the end of the psu?
Anyone know the distance between the side case wall and the motherboard for this? Just saw the preview of the EVGA GTX 680 Classified and it's 5.25" tall... Same as the GTX 580 Classified.
What the hell is with Silverstone's fetish for slot drives? I dont mind laptop drives, but will never stick one of my valuable discs in a slot.
Judging from the picture of the 180mm top fan it looks to be about 160mm (over 6") of clearance. There may be any issue with the 120x25mm side fan at the bottom but a 15mm fan should squeeze in. The cooler shown in the photograph is Silverstone's new SST-NT08 which has a 120mm fan imbedded so it appears to have a 130-140mm height from the MB.
i prefere it on small cases, why waste the space on a 5.25" ODD when it virtually never gets used, and gets in the way of decent cooling?
I think his point was not slim drives as slot drives per se. I. personally, have never had a slot drive eat a disk on me and I do prefer the looks of a simple slot. Having said that, I don't think it would made much of a difference to have a slim tray drive on this model, appearance wise.
Vastly better. Silverstone should hire you as a design consultant.So is this leagues better, or what?
Vastly better. Silverstone should hire you as a design consultant.![]()
it is ugly.
Condense it all as bootable images/installers/software on something faster and more convenient than optical. They're almost floppy drives these days.
FINALLY - that layout.
I agree the exterior looks a bit ugly, but finally a major company has decided to put the power supply in that position in a "normal" case (ie, not the FT03).
Finally someone gets it. Looks like the perfect matx case for volume/performance.
I'll take an ever-so-slight reduction in airflow for a quantum leap in aesthetics, thank you very much.Could we have designed the look of the plastic grille differently so that it resembles a metal mesh grille? Yes probably, but it wouldnt be as strong structurally (going from metal to plastic) and the ventilation wouldnt be as good as the current design.
