SILVERSTONE ST60F-P 600W ???
bastage
Pics of your wife?
http://www.newegg.com/Product/Product.aspx?Item=N82E16817256064
so I had my main rig sell last night & had to order a psu as well as my other parts.. so the reviews I have found are good, but nothing that I consider to be an expert review..
So before I get this thing & open it, how is it..
and this will be running a mITX Phenom Rig, I just wanted to fully modular & the oo05 short cable kit for this that newegg sells..
Posted via [H] Mobile Device
It's still made by Enhance according to the UL number. So it should still be of decent quality.
The two problems I have with that PSU is that it only has a one year warranty and only has 42A on the +12V rail. A tad low for a 600W PSU IMO. Especially considering that past Silverstone 600W PSUs (even Enhanced made ones) had 48A on the +12V rail.
well thats a bummer.. Is there a better one that has a short cable kit, errr well is there any other psu's at all that have a short cable kit?
How about the original ST60F?:
$100 - Silverstone ST60F 600W Modular PSU
3 year warranty and 48A on the +12V rail. Also compatible with the PP05 short cable kit. It's an oldie but it's still of good quality
hmm newegg has that listed wrong.. it doesn't come up when sorting for modular units. i guess if thats the only other option that i will stick to whats already been ordered so i don't have to pay return shipping and the restocking fee.. especially since this is going to be in a mITX so only a single video card & most likely will be downsizing my 5830 to either a 5770 or maybe a 460. & the motherboard doesn't support over a 95w cpu so power shouldn't be a huge issue as long as the psu isn't complete crap.
Just to clarify on the warranty length in North America for SilverStone power supplies. All models 550W and above plus fanless models have three year warranty, so the ST60F-P has three year warranty as well.
Both ST60F and ST60F-P are more than enough for any Mini-ITX builds. The main difference between the two is ST60F has dual +12V rails while ST60F-P has single +12V rail. Even though both have 80 PLUS Bronze certification, the newer ST60F-P is more efficient.
being as its kind of tailored to a mITX gaming build I think I made the right decision (between the fairly shallow depth & the completely modular design). Tony Ou thank you for the response & the clarification on the warranty. That does make me feel a little better about it..
