It's definitely on my list of things to do in the near future though.
It opens doors, and can be quite a cheap hobby to start off with
Or an aftermarket SFX-L enclosure that fits the SX600 internals (or ST45 guts) with a better quality 120mm fan?
Basically, an SFX to SFX-L conversion kit.
I tried a little but it was hard to see anything through the vents. I did notice that the part of the grill under the AC inlet was much warmer than the air coming out of the rest of the grill. The AC inlet is seems to be blocking the airflow from the fan but while the air felt warmer what I could see through the imager didn't look much hotter than the rest of the PSU.
Once I can get the second card running in the bottom slot I'll do a lot more noise testing. Right now it's pointless because the top card drowns everything else out.
I've done some digging but I haven't come across any suitable replacement fans yet. Unfortunately I haven't found any 80x15mm fans with FDB or something similar at the RPMs needed to work here
One off the wall idea I had was to make a SFX-L sized case for the 600W
Backfeed, ran Unigine Valley with the Extreme HD benchmark.
The power use fluctuated between 250W-400W depending on the scene.
The fan RPM was between 1350-1450 RPM the entire run and the exhaust temp got up to 30.2°C (ambient was 25.5°C).
That's a really good idea! But, I'm guessing there'd still be a problem with finding a suitable 120mm fan then?
That's excellent, especially if the power measurement is on the AC side?
Hopefully something will come up. If there were a simple way to positively offset the voltage (i.e. add a constant +3V or something), it should be a lot easier to find a suitable fan (?). But I can't think of any simple way.
Answering myself, it should be possible to use a summing amplifier to do this, adding the voltage from the psu fan controller to 3,3V from the psu itself? I'm not an electronics engineer though, so there are probably several problems with this...
That would be nice but Sanyo and Nidec Servo only make 2BB fans, no sleeve or sleeve-variation bearings, I think.I looked into it when I learned the Gentle Typhoons were being discontinued because my dream fan would be a GT with PWM and FDB with a black frame with red blades ..
Anyway a fantastic work, Aibohphobia, a lot of useful measurements! And I'm also looking forward to your case! (Hopefully a prototype next month?)
I'd buy that
Overall I think if you really really want a 600W+ SFX-L then you'd be much cheaper off importing the Dirac from Japan.
As you may have read before at another place WiSK you know I got you know I got all the machinery and skills ...
I don't know about that. There's a company in Japan called Tenso that offers a buying service where they'll buy the item for you and have it shipped to their warehouse and then it'll get forwarded on to you anywhere in the world.
The 650W Dirac including tax, fees, and shipping would end up costing around $240
So $110 more than the SX600-G. Where can you get steel cut accurately and folded, and a good fan, and return-postage to someone who can desolder for you for $110?
Tony must think we're crazy, considering recasing the PSU and tapping voltage from an internal line in order to use a slim 120mm fan so it can power a hexacore and SLI 980s as silently as possible
$240 is acceptable to me, but what was the plan here; to cut a larger hole in the case and replace the 92mm fan with a 120mm? Or just hope that the 92mm is actually any better than the 80mm in SX600-G?
I see SilverStone releasing a new revision (v1.1 or 2.0) later to replace the lower tier parts with better ones.
I really hope they end up doing that with the crappy caps
Scan now have them in stock.Any word of these arriving in the UK? Both Scan and Overclockers show them as Overdue.
link?
I think he was saying that he could see them coming out with a revision at some point to address this issue.
Either. I think the extra room in the case will allow for better airflow so maybe the 92mm will be enough to quietly cool it. If not it's nothing a dremel can't fix
The modular daughterboard connected directly to the main board instead of wasting space of all those wires. I could go on but really I know nothing about high end PSU tech.
Mate, is there any chance you can get some voltage range readings from the PSU fan wires themselves? I'm having no luck finding quality fans that can start and run low enough.
Hmm. The working range of the fan controller seems to be roughly 3 to 6 V? If the fan controller voltage was added to itself, i.e. by Y-splitting the wire and using a summing amplifier, the range would be transformed into 6 to 12V. There should be a bunch (well, one is of course enough) of quality replacement fans in that range?
To add an additional component introduces extra difficulty and costs. It needs to be tiny to fit, easy to buy and connect.
What about a 5V fan? Qualtek make 80x15 fans either 2-ball, hydro or sleeve bearing. Unfortunately the spec sheet doesn't say if 5V is the upper limit or just the recommended operating voltage.
http://www.qualtekusa.com/images/Fans/pdf_files/FAD1-08015.pdf
Ok I got some readings. I didn't get the full range because with Prime and FurMark going the fan wasn't ramping up to full speed and some of the components inside were getting to 80°C! I think not having the top panel on was messing with the airflow causing the temp sensor to run too cool so it wasn't increasing the fan speed as much as it should.
What I got matches the results I got testing the fan by itself though. It started at 1V and slowly increased until 3V at which point the fan starts turning. As it got hotter the voltage increased until it got to 4V @ 1600 RPM (which matches the chart here). That's when I stopped the test.
So the RPM and voltages I got testing the fan by itself match what the PSU header is doing, no funny business going on.
Edit:
Just noticed that with the machine idling the voltage is 3.05V, right at the fan's starting voltage. I wonder if the voltage/temp curve is slightly off and it never drops quite enough for the fan to shut off after it's come on.
Nidec does but as far as I know it's been limited to specialized applications like ultrabooks. I believe some of the MacBooks use them.
http://www.nidec.com/en-NA/technology/story/uff/
Can't find this on the Nidec sites but they do list what seems to be its successor, UltraFlo U80R12MHAB-51. I don't know if this fan starts at a much lower input voltage than what's said on the spec sheet (like San Ace fans often do) but regardless 3100rpm@12V is probably too low as an SX600-G fan replacement where we want something like 4800rpm@12V so it's probably not a good candidate.
I wonder why Enhance/Silverstone decided to go with the combination of a high rpm 12V fan with very low input voltage control rather than a medium speed fan with an input voltage ranging like 6-12V.
So, this is pretty strange: I'm using my sx600 on my gigabyte z87n board for a week now and always noticed this tedious buzzing sound it makes when the pc is powered off but still plugged into a power outlet. Turns out disabling ERP in the bios fixes this problem. Does anyone know the reason behind it?
