Cov
- Dec 3, 2007
Has anyone this case in black or white and could show off some pictures please ?
(W) 270 mm x (H) 212 mm x (D) 393 mm
The stripe on the front is a one-way-mirror. On the left are two blue LEDs for Power & HD.
On the right hand side, behind the lid, are the sockets for USB, headphone ect. and the on/off switch is on the top left-hand side.
I would love to see some moddings
The chassis is made of aluminium, but the cover is a single piece of foldet steel.
Inside are spaces for 3 fans, the case however only comes with one fan.
The weight for this case is only 2.6 Kg !
The CPU cooler cannot exceed 78 mm in height, so it has to be a low profile cooler.
A normal ATX PS fits fine, but the combined depth of power supply and optical drive cannot exceed 355 mm.
This case has no problem fitting a GeForce 8800 GT into it.
I only wished Silverstone would have made it completely in aluminium, including front.
The front is made of plastic.
