acairman
[H] Memes of Truth
- Apr 24, 2012
Amazon notice today, case has shipped.
Warning, the Corsair H80i does not work well in this case in combination with the ASUS Gryphon z87 board.
The radiator will only fits in one orientation that doesn't hit the top fan or the heat sinks on the mother board or prevents the case from closing. However, in that one position it goes over the first PCIE 3.0 slot. You will have to move your video card all the way to the last PCIE slot so there goes any chance of using a second GPU card.
Furthermore, you will have to remove the bottom fan that attaches to the GPU fan area if you install an AX850. The fan is 25mm in width and hits the power cord going into the power supply. You will be unable to close that compartment without damaging the cord connector or the fan.
I am ordering some Noctua slim 92m fans that are not only dead silent but slimmer. The fanes on the GPU fan side can take 80 or 92's with the 120 slot compatible with a 92 mm fan as well.
Case is gorgeous and the wire management is awesome. This is my favorite built ever. Can't wait for the 780 GTX to arrive from the step up program. I will be sending back the H80I and buying the HE01 which according to [H] is equal or better to the H80i. (I prefer the H80i since this is Miami, FL and water cooling works better when there is a lack of cool air.)
These are the fans I'm ordering. Noctua NF-A9x14.
http://www.amazon.com/gp/product/B009NQM7V2/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=A21UKLVMUAO7H3
And this cooler: HE01
http://www.amazon.com/gp/product/B008N8GELA/ref=ox_sc_act_title_2?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
I may not ever do SLI/CFX however after selling my last rig (everything sold as once) I know this will be a problem soon or later.
HE01 VS H80i from [H]
http://hardocp.com/article/2013/02/...s_h80i_h100i_cpu_cooler_review/4#.UbyjlhbBxSU
Hope this helps any of you out there with this case or looking to buy it.
I would have just gone with a pure Noctua solution. Probably cost the same.These are the fans I'm ordering. Noctua NF-A9x14.
Damn wish I had seen this thread. Just got most of my parts in (other than my mobo). I had planned to eventually go SLI/CF but if hte H80i blocks it...may just have to mod the top fan/find a thinner one or just buy a single beast GPU and keep it in the lower slot.
Soo, is it worth paying 30% more than SG09? I can't decide if it's less ugly just by looking on photos and I can't find it locally to put my hands on![]()
Where are you seeing that the SG10 is 30% more expensive than the SG09?
EU. SG10 is not as well supplied as SG09 yet, so the price is kinda meh.
But I need to buy a case ASAP, so I'm wondering if the price difference is worth it.
Side question - can anyone suggest similar but a lot better looking case in similar (or lower) price range? It can be a few liters larger, that's not a deal breaker.
