Hey guys,
I am wondering, would the Corsair AX1200 PSU fit with Raven 03?
The spec of the RV03 says Limitation of PSU : 180mm
but the dimension of the PSU is 150mm(W) x 86mm(H) x 200mm(L).
As we can see the PSU is 20mm longer than the limitation, but does it have to be exactly 180mm?
can I just fit the psu into that slot?
Thank you in advance guys
ขอบคุณครับผม
ขอบคุณครับผม
