@all: Just wondering: As the Thermalright HR02 Macho and the Noctua NH-D14 often seem to perform equally well in a semi-passive setup I was wondering which one I should use for my soon to come Ivy Bridge based semi-passive system? I am tending to the Noctua...
@DrRetina: Thanks for the answer. I was going to go for a 3770K as well, but was going to get a reference design HD 7770 and supply it with a nice Arctic Accelero S1 PLUS. I don't need that much gaming power, so the 7770 should be more than enough and according to Arctic it should be able to cool it (semi-)passively.
However, I was also thinking of installing one silent PWM-Fan as a backup on the CPU heatsink and will most likely go for a Noiseblocker Multiframe M12-PS. Other candidates are bequiet SilentWings or the Alpenföhn Wingboost (did I mention that I am German?). One of the non-PWM-versions of the Noiseblocker will probably serve as case fans.
I am having issues with my front panel audio jacks, they can't be used.. everything I plug into it just pops out because the jacks are so recessed into the plastic that unless I shove in the plug and hold it there, it will not make contact. I tried to tighten to screws and reseat the PCB but it's still not good enough. Any fixes or a replacement front panel jacks, maybe with USB3 headers this time?
One thing about the front audio jacks is that they are grounded to the USB ground, so you will get noise from them anyway. First thing I did when I opened up the case was cut the glue and pull those wires out. FAJ are worthless to me since I use external sound cards. I know this doesn't help you much, but FAJ are largely best avoided by many case makers. Almost always unshielded and grounded improperly.
Yeah, I guess I'll just get some male to female 3.5mm extensions. Sucks to have them and not be able to use them though. I may move my X-Fi Titanium over but too lazy to take it out of my old rig.
Only issue I have with my Creative is they have shit driver support. Why can't they just bundle a simple all in one driver? I have to install 6 different things to get full use of my card.
Their USB cards require no drivers. That's specifically why I have the XFi Go Pro for all sound and the XMod for recording. Then again, I don't use faux surround sound effects and the windows built in volume control sliders do well enough. I adjust everything else on the amp.
That was a good one (i mean joke). Well, technically yes, they don't require drivers. But Creative X-Fi Go Pro is sub-par without them - i mean the data flow to the sound card is underprioritized, so when you get a bit higher load on system, the sound would simply stop (happened to me on HP Microserver with 1.5GHz Athlon II Neo N40L). Once drivers were installed, no sound problems at all.
Is there in any difference in sound _quality_ with the Creative specific (as opposed to generic usb sound) drivers?
will this kind of vertical case be a problem for a graphics card with heat pipes oriented like this:
http://cdn.overclock.net/1/1a/1a2b70d2_180e.jpeg
or, more specifically, can i put an Asus 7979 CUII TOP card in a FT03?
cheers
Q. I have a custom cooler, how do I know which way the heat pipes should be situated to obtain the best performance in the FT03-MINI?
A: There are two main types of heat pipes used in popular aftermarket coolers, they are groove and powder. Groove heat pipes are very susceptible to gravity while powder heat pipes are less so. To achieve best performance in either heat pipe technology, they need to be placed horizontally or have the heat source side located below the other end of the heat pipe. We recommend choosing and installing components with heat pipes carefully by taking into consideration of the following examples:
Sweet review! Bought this card after testing a coulpe different 6950's (ref/TFii/DCII) in my FT02-chassis. Didn't record any change in temperature between horizontal/vertical setup with this card, as opposed to both the reference and the DCII cards that run significantly (about 10c) hotter when mounted as supposed to in the ft02. Running stable and cool @ 900 with the silent fancurve.
So for the past couple of days the FP audio ports kept detecting something being plugged in.. weird as hell, every few minutes my drivers would detect a mic being plugged in and then suddenly it's gone. It was extremely annoying so I unplugged the FP, I need to buy that USB3 upgrade kit.
What cooler in one of these for 3770k? Will it hold a Megahalem?
