I think this is great idea. I can imagine something like this can also be used on the FT03-mini too. Well done!
1. The top fan had a broken fan blade. No piece was found in the case so I am assuming it happened before I put my system together and I just missed it. This was the source of the vibration.
Here's mine;
Unscrew the fan housing? One screw at front, two screws at the back.
Here's mine;
Asus Rampage IV Gene X79
i7 3970x - Corsair Hydro H80i
16gb Corsair Vengeance LP
EVGA GTX 680 SC Signature 2gb
Corsair AX860 PSU
2x SP120 & 2x AF120 Corsair fans
There is a couple of cable routing holes cut out behind the fan housing but both are too small to fit the head of the PSU plug through.
Could you tell me how you managed to route the PSU cable behind the bottom left 120mm fan housing? I tried a couple of different ways and so far haven't figured out how others have been able to get it to fit because the hole cut out for routing cables back there is about 1-2mm too small for the PSU plug to go through.
That could work, though I am looking for something a little less jury-rigged.
your crasy xD
yes yes i think it would be better i put it in 3 2,5" case. Sorry me english is very bad i translate with google german-englishWhat is that your housing your hdd and sdd in? So lovely.
Here's mine;
Corsair AX860 PSU
what kind of temps and noise are you seeing on the 680's? What are you using for cooling?
I am thinking about adding 2x H60 for each GPU using DWOOD or RedMod.
