ToastyBread
- Sep 8, 2009
So for those who've used a Corsair H50 or H70 in this case, what type of idle temperatures have you been seeing?
I built my system this morning, with an i5 2500K and the new Corsair H60. I mounted the radiator fan so that it is blowing out of the case, and I used the Silverstone fan that came mounted to the external 120 mm mount as the second fan on the radiator (so it goes: Corsair fan -> Radiator -> Silverstone fan -> backpanel / case top).
Using this configuration, and with all the other 120 mm fans mounted as they are, currently my i5 2500K is idling at 46 C, which seems really high...
Any thoughts or ideas are greatly appreciated.
Edit - I should add that if the system is shut down and let to sit for awhile, and then I go into the BIOS and check the BIOS temperature, it shows that it starts off around 41 C, then climbs to 45-46 C. Given the rather high temperature it's even beginning at, could the BIOS simply be mis-reporting the temperature?
It shows the motherboard temperature as 30 C, which at least seems more reasonable.
