The small fiber washers that came with my case are to be used with the Mobo, correct?
If so, then do they go between the Mobo and the standoffs or between the Mobo and the head of the screw?
I know this question may be silly, but this is my first build and I want to make sure I get everything right.
I've already installed the Mobo and it went into the case just fine, but after finishing the job, I remembered the washers. So I guess if the washers go between the Moobo and the Case I've got some work ahead of me. If they are just for the screw, then I can just take each one out one at a time and add on the washer. Are the washers really neccesary?
Anyways, thanks for any help on this.
