Signed up for TDS
Comixbooks
We been on a 2.1 meg download connection since 2013 my parents sign up for Fiber last month they put up Fiber lines in our area few Months back.. Sometimes I wasted all day downloading when I could have been playing the game instead.
Our connection was so slow on ATT due to being on 1960s phones lines.
The guy should be here Wed to install a Router.
i ran into this prob when i was a teen still living at home. i got my own cable connection installed...
Going from 2.1 meg connection to 1 GB
I would have to stop my downloads just so my Dad could could surf. He would ask me if I'm downloading all the time then I would throttle my 2.1 meg download speed to like 1.2 or something. I plan on using my wifi adapter on my Motherboard instead of Cat 5 to the Router which never did me much good. Since the Walls were all phone lines.
This really takes away from having a lot of SSD space for games which I cherished since my speeds were so slow. I Like having many games installed anyway so I don't forget about them.
Yeah, even 10Mb would be a huge upgrade. 10 is the minimum most places (or is it 30 now?), even for DSL, and isn't too bad if the connection quality is good. You will be dumbfounded by 1Gb.
I haven’t had a 2 Mb line since like … high school? Middle school? 2 Mb was my first upgrade to broadband DSL from dial up. That is an absolutely massive upgrade you’re getting.
You're going to love it! 2mbps must be very difficult to use these days.
2mbit was fine when websites were small and designed to be fast loading. But today, good lord no.
Looking foward to not crashing games due to slow connection sometimes they would lag out. I might install some PS5 games like Battlefield 6 and COD since TMP 2.0 doesn't work well with my PC MB.
I have TDS, when they work they are fine. When they don't you have to prove you have several IT degrees in order to get service and the small print says we only guarantee 60% of the advertised speed.
Does the service go down alot? I'm fine with half the speed it costs alot less anyway.
I am in Maine and we get some outages due to a lot of trees and winter but overall it is reliable. The real issue is that if you have either an intermittent issue or a regular issue like speed loss, it takes forever to get them to respond and to actually do anything.
They cut around our trees along the curb they have big holes for the wires not sure where the signal is coming from.
The guy had to put the Router on the Bottom floor I'm getting speeds all over the place like on Epic it started off at 450MPS then it slowed down to 45-50MPS.
Maybe i can swoop up the Wifi antenna on my PC or something or I might be stuck with this speed. TDS didn't even set it up it was contracted from Desert solutions or something.
I would have to do that I guess but would have to run a cable downstairs.
It jumped back up now
Took me about 2 hours to download GTA5 premium edition it might of took me 2-3 days with my 2.1 meg connection the reason why I never downloaded it. I had it downloaded one time but I think the Epic launcher erased it or years ago.
Before
After
I was getting Brain Fog for the first two days I'm not sure what it was from. Seems a littl but better today I adjust the angle of my Wifi antenna pointing away on top of my PC seems to pick it up better. It's just held in place by straps from my Asus Tuf case.
youd be even happier if youd hardwire, then youll get the speed your paying for....
oh and those dl speeds will vary based on the game and user #s
Before
After
Faster internet means more wifi waves interfering with your brain waves. Your brain just getting used to it now.
Oh ok, so it was "2.1MB" not "2.1Mb". That's better. Not good, but better than what I was thinking. Back in the day I had DSL with speeds like 768kb or 1.5Mb over old copper phone lines. You had me thinking you were stuck in the 2000s. First DSL service I had was in 1999. It was 768kbps and was not cheap. Over $100/mo. Of course speed went up over time. Year or so later I was at 1.5Mbps.
I was stuck there until last week. I had 765kb untill 2013 then went to 2.1 which is basically double only from 2013-2026
