Armenius
Extremely [H]
- Jan 28, 2014
Enable the alternative HUD. It should display blue when you're over 100 armor, by default.It there a way to set GZDoom to display armor percentage in blue or otherwise indicate that you have Mega armor? Seems this would be a more common feature in source ports but not having luck finding anything.
Yeah I saw that part, but you can still have the normal Armor and be over 100 or be under 100 with mega armor. I try to keep mega armor as long as possible because it provides better protection.Enable the alternative HUD. It should display blue when you're over 100 armor, by default.
The icon of the armor you're wearing in the alternative HUD is consistent with the last one you picked up. It will stay as the blue combat armor when you drop below 100 armor until you pick up a security armor.Yeah I saw that part, but you can still have the normal Armor and be over 100 or be under 100 with mega armor. I try to keep mega armor as long as possible because it provides better protection.
Thanks, I'll check out the alternative hud.The icon of the armor you're wearing in the alternative HUD is consistent with the last one you picked up. It will stay as the blue combat armor when you drop below 100 armor until you pick up a security armor.
