I have some difficulty finding cases where you side insert/extract the HDD.
This I have found to be of the most practical and easy way to deal with frequent HDD swap.
They also have to provide specific 120mm fan ventilation for the HDDs.
My longest experience with one was with a Coolmaster, but it did not have a bottom power supply, which I started to appreciate on my present Antec P-180 mini case, which unfortunately does not sport side insert slots.
I already found the Corsair Carbide series, which seem to fill the bill. But I would like to be aware of other types that you may know so I can compare them.
Some brands and models are not available where I live, Brazil, so that's another reason to increase my options.
Even if you know just one it already helps me.
