- Apr 11, 2007
I built my parents a Shuttle system in June of 2009 after my father fell in love with their small size.
It was a Shuttle SP45H7 system. The power supply that came with it was a 300w unit, model # PC61. The system was built with 4x2 GB RAM sticks, 1x Nvidia 9500GT, 1x 500GB Hard drive, 1x dvd drive, and an Intel Q8200 95w quad core processor. Fan settings in bios were set to automatic after a few days of monitoring its use since the box never exceeded 60c in normal use. It even had no problem crunching prime95 for first few days to help stability test it and the cpu stayed under 70c when the fan kicked into high gear.
The original power supply burnt out in 6 months. I was positive it was dead since its little fan no longer spun, it no longer posted, cold boot didn't fix it, and plugging in a full size ATX PSU let the box boot right up. The box was almost immaculate, almost no dust accumulation anywhere (including psu) after 6 months since my parents are neat freaks.
Fearing I might have overloaded it and trying to be cautious, I ordered the 500w PC63 unit to replace it. The 500w PC63 was an upgrade unit for my box, and it was the default psu in shuttle's x58 systems and even had 2 pcie plugs for high end video cards. It had more than enough power for my box.
Fast forward to yesterday, and the replacement PSU died also with the exact same symptoms as the first one. No dust accumulation in the box or PSU, canned air blew nothing out of the PSU after it was dead. Right now the box is being powered by a full size corsair 430w PSU with the case's main cover off to allow the wiring to be plugged in until a 2nd replacement shuttle PSU can be ordered.
-Original 300w PC61 psu lasted 6 months.
-Replacement 500w PC63 psu lasted 18 months, ordered from axiontech.com.
-2nd replacement 500w PC63 ordered yesterday from amazon.
Lasting less than 3-5 years IMHO is inexcusable, especially in a box where the most computation it has ever done is an excel spreadsheet and the CPU temps never went over 60c. There is no way this box uses anywhere near 500w even under full load.
What is going on? Are the shuttle psu's shit or am I just extremely unlucky?
