Last week I bought a SD31P along with a Pentium D 2x3.2GHz processor, 2 x OCZ 1GB RAM and a 200GB SATA 2 hard drive. I have also installed a Shuttle WIFI module but there is no floppy drive.
I have installed all of these components using the instructions in the manual but when I switch the machine on, it seems to stay on the Shuttle X-PC splash screen and does not continue to try and boot.
I can press DELETE to get to the BIOS settings which seems to recognise all the components correctly.
As the SATA 2 hard drive is new, it currently has nothing installed on it. I have tried an old IDE hard drive but the same problem occurs.
Does anybody have any ideas as to what the problem might be? Or some BIOS settings that may be worth checking.
After reading another thread in the forum, I might try disconnecting the Shuttle Card Reader and see what that does.
Any advice?
Any advice?
