Shuttle Forum
Hawk88
Does anyone know a good forum dedicated to the Shuttle brand. I just picked up a KPC K45 system and wanted to share/look for ideas. I am planning on using mine for a Windows Home Server. Just picked up a 750Gb hdd and put in it. Thought that the sticker for the warranty was funny. I didnt get the barebone, I got the one with Linux installed. There is a warranty sticker on the outside where you take the case cover off. So basically if you wanted to upgrade the memory, you void the warranty because you have to remove the sticker to take the cover off. Lame.
I got mine from newegg and at last check, they still did not have the barebones version. I couldn't wait. I figured the memory and the processor was "worth" me not waiting any more for the extra 100 bucks. Thanks for the forum. On a side note, I made a usb bootable key last night and started to copy files from the Windows Home Server cd to the key. A total of just over 1Gb in files took over 5 hours to copy (I think, after 3 hours I went to bed and let it run, but it said it had over 2 hour to go) to the key. If you guessed it, I have Vista installed. I like Vista, but that sucked balls.
