I have a couple questions...I have a shuttle sn41g2 and i was wondering about changing vcore and vdimm in the bios. There isn't a place in the bios to change it. I was wondering if there was some sort of hacked bios that allows you to change those settings. I would like to get this running stable at 3200+, but i'm kinda worried about temps in the small shuttle case. Right now my cpu load temps are ~48C and my case temp load is ~45C. I'm using the ICE cooling in the shuttle and i was wondering about upgrading the fan. I want something that pushes a lot of air, but it has to be 80x80x25mm, because a 80x80x38mm wouldn't fit. So my question is, what fan should i use?
Note: I haven't cut out the grill in the back yet, i know this will lower temps a lot.
The specs are as follows:
Shuttle SN41G2
nVidia nForce2 chipset
Barton 2500+
512MB pc3200 Mushkin lvl 2 512x1
On-board Geforce4 MX
40gig WD HD w/ 8M cache
lite-on 48/24/48/16 combo drive
Shuttle SN41G2
Barton 2500+
