Originally posted by Z3Px
hey poundofflower, what is the name of that stat monitoring module you have running?? i want it. I just installed fluxbox for freebsd and i really like it. I advise others to do the same. lol thanks
Go to rename them and hit ALT+255. You will have to rename each with different # of ALT+255's or windows will get confused as to what it is opening and open one program you click on another, ex. rename IE to ALT+255+255 and My Computer to ALT+255+255+255, NOT ALT+255+255. To rename the recycle bin you will have to create a shortcut to it on your desktop then remove the original one with something like TweakUI.Originally posted by compslckr
how do you make your icons not have writing under them? i did it once, but dont remember how
SchweetOriginally posted by compslckr
thanks, as for the recycle bin you can always right click it and go to properties and change the name there![]()
