hmph, i think CM's measurements are wrong, its too bad i didnt notice it earlier but how can the heatsink be 80mm wide lik they state if it uses a 100mm fan?jmroberts70 said:lol, I never actually considered them "sexy" but I'll take it!! Surprisngly, I didn't realize that Newegg doesn't have decent dimensions for these guys. I'll have to break out a tape measure tonight or something and make some simple measurements for you guys. I will say that some video cards simply won't be able to fit in between them.
**edit** Just found some great info on the CoolerMaster website with some good dimensions 'n stuff:
Chipset cooler
Hyper 6+ CPU cooler
Enjoy!!
I think we've got a new record here folks! The worlds largest microwaveryuji said:guess your router makes more heat then mine does, odd since mine has a explanation, i only have it at 8 times the power outputits then amped by the 8 dBi antennas i put on... the signal is so powerful that when my mom takes her 5 ghz cordless phone in here you get a ton of interference, i keep 54 megabits a good 200 feet, yet my sister still blames my router for not being able to connect from the basement when i get perfect signal from down there
naw anything that the router can output for power levels isnt enough to even hurt a ant the signal output isnt that high stock because fcc regulations limit it, i just ran the hardware at the output levels it was meant toUnknown-One said:I think we've got a new record here folks! The worlds largest microwave![]()
mickey987 said:I got carried away with the picture taking when I installed my XP-120...![]()
Just out of its wrapper!
Tiny said:*snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip* *snip*
damn nice! wat was the cpu clocked at?Tiny said:The Sonic Tower paired with a Nexus 120mm was 32c/42c (45minute idel/45minute CPU burn-in)
The Hyper 6+ (although I am unable to properly attach it to my board as the back plate doesn't clear some resistors...I just rested it on the CPU and tested it....I don't recommend doing that) 29c/36c same test as the Sonic Tower.
I am not going to be using either one though....I stuffed everything in a Qpack case and obviously can't use the larger heatsinks.![]()
chill man its juss a chipset coolerHappy Hopping said:http://www.newegg.com/product/product.asp?item=N82E16835103169
that's insane. There is no way the wt. of the motherboard can hold w/o cracking in long term. And it's crazy for the designer to design such a large heat sink. Even Xeon don't need it.
What are we cooling? Himilaya servers?
sh0w me some unique pics of itRev. said:I have an XP-120 on my Hammer, and I love it.
jmroberts70 said:![]()
My system barely get's warm now!! The fans are nearly silent. Now all I hear is that pesky GPU cooler fan (soon to be replaced) and a couple of case fans (also planning on replacement now that I can hear them)
mpegripper said:can you use your own fan with that heatsink? I'm guessing you can if its a standard size
edit: dammit 100mm, so how loud is this thing
and anyone know of a place that sells the hyper 6 not the + version, i would like the 80mm fan so i can mount my own
http://www.svc.com/hyper6-19.htmlmpegripper said:can you use your own fan with that heatsink? I'm guessing you can if its a standard size
N H O said:
actually the CNPS9500 is only 530gryuji said:thats gonna be about 1 kg as well
suit urself, i rather deal with the 1kg and pay 1/3 of the price and find a way to safely mount it and have almost the same coolingmpegripper said:thanks, but i have now decided not to try and mount a 1 kg heatsink, that's just ridiculous
i'll go with the cnps9500
i LOVE it man.....xp120's are the shit!Rev. said:
QFTryuji said:you have far too much enthusiasm in heat sinks my friend...
N H O said:
yeea its badass and would be a l337 cooler with two tornadoes, but the bad about the heatsink is that its position cannot be rotated, so if ur cpu socket is rotated 90*, the cooler will be facing upwards as opposed to the hyper 6+ which can be rotated due to its mounting system...and IIRC, the hyper 6+ was a better coolerjmroberts70 said:I LOVE the all-copper version here! The sale price rawks too!! It looks like this is actually a smaller cooler (at 80mm as opposed to the Hyper6+ that I have at 100mm). But then again, with copper, you probably don't need the size (at least that's my guess).
