Should i upgrade my mb?
PhattyT
alright well... with all the dd2 prices going so cheap! i wonder if i should upgrade my mb to use ddr2? ddr is too expensiveee to upgrade more memory... :mad:
my mb is currently
-A8N5X
CPU
-AMD Opty 170
any recommendation on what motherboard i should get that is capable with my CPU?
price range about 70-80 tops for new or used.
thanks!
you can't change to using DDR2 without also changing your CPU - the combined cost of new CPU/RAM & mobo will be more than your budget.
oh ok.... so i do have to change my cpu too.... =[ , thanks for the info!
You could probably sell your whole mb/CPU/memory and get a whole new setup for the extra $70-80 you want to spend.
