Should I reinstall my OS?
texmaster
I ran this setup rock solid stable for about a month waiting for the r600 but decided to go nvidia.
Running XP:
My specs before
Intel Core 2 Duo E6600
GIGABYTE GA-965GM-S2 LGA 775 Intel G965 Express Micro ATX
CORSAIR CMPSU-620HX ATX12V v2.2 and EPS12V 2.91 620W Power Supply
1 mushkin 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel
WD1500ADFD 150GB 10,000 RPM Serial ATA150 Hard Drive
Thermaltake Lanbox
Thermaltake Blue orb II CPU Cooler
Specs changed
Intel Core 2 Extreme QX6700
BFG Tech BFGR88768GTXOC2E GeForce 8800GTX 768MB
So basically I put in a faster processor, big ass vid card and another 2 gigs of ram.
Should I reinstall my OS or can I get away with leaving it as is?
You might want to reinstall OS. Even if you don't have problems short-term, when you try to get updates, you will be told that your system has been changed (or something like that) and it'll eventually force you to "buy a genuine copy of XP".
The geniune copy I've got. Its just a pain the ass to reinstall everything all over again.
I am however having some kind of error on bootup every now and then that freezes everything and I have to reboot. If I could be sure it was the OS I would reinstall.
Doesn't a "serious" hardware change in windows just require re-activation? It shouldn't balk about it being genuine or anything.
no need to reinstall the os. typically when you're changing mobos and going from one chipset to another it's a good idea to reinstall the os. but with a processor swap and a new video card, there's no need.
Agreed.. it sounds to me like you may have some hardware issues, not so much a software problem. Re-seat everything and make sure that everything has power connected correctly..
Well it kept locking up so I did finally reinstall everything. ugh.
Seems to be ok...for now
Ok just got another random reboot AGAIN
Saw the blue screen of death for a split second then it rebooted. Of course XP doesn't say a word about the F up.
Where should I start looking for the bug? Vid card? New Ram?
More info: I kept it on all last night and no problems so it seems to occur when I'm doing something on it a not when its idle.
It also ran through 3dmark 06 without a problem.
Prime95 has a few different stress-test modes. See if the RAM-heavy or CPU-heavy test is what is causing it to crash. Vid card isn't going to be the primary culprit, but, the power supply is also a possibility, so having a power hungry video card may be pushing it over the edge
Change the Windows option so that when it blue-screens it doesn't auto-reboot. Then you can see the error and look it up.
This is under the "System Properties">"Advanced">"Automatically Restart" option.
Also try the latest "Ultimate Boot CD" to stress test your computer and do a full mem test.
what psu are you using? like Buckus said, change the automatically restart option so you can actually see the error message. have you tried using memtest? booted up with only one stick of ram? any overclock?
He did mention his psu in his original post, it was a....
I don't think that's his problem.
I think the ram is probably the cause of your problem. The second most likely cause would be the video card, and CPU would be least likely imo. I'd do what o0akoni0o suggest and take out some ram and see what happens. Some mobos have very specific requirement for how much, and what kind of ram you can stick into them.
Ok let me ask you guys this.
I did memtest a few times only getting to 6% but no errors before I had to halt the test to get back to work.
Now, doing the same test, first shot I got errors by the third test.
Ran it again and got errors in the 100s of thousands.
Is this normal to have results accross the map???
This is not normal, memtest should pass with no errors. Sounds like you got bad memory or a bad motherboard - more likely memory.
yeah but is it normal for tests to be that different on the same system?
It's normal to me. Thats what I always recommend running it for at least three hours or 24 hours max. Time to RMA that RAM
Yep, you found your problem... your ram is fried.
Well of course you guys were right.
This POS ram was so bad it locked up in memtest!
Sadly though the heat produced by my QX6700 is so great if I want to be assured of keeping the thing cool enough, I'm going to have to go back to large cases.
no more Matx
