thanakornl
- Dec 10, 2008
Hi guys,
Problems with NEC 2490wuxi again... This time round:
1) When i test the screen using black, i can see the bottom left with alittle reddish.. Is this normal?
2) Again using black color, I can see one area where there's a small red pink line on the screen (very small)? again is this normal?
3) When i tested the screen with white or red solid color. With white i can see one dot that turned blue!!!! and that same dot turn black when tested with red. Is this normal?
Should i call up NEC and try to get a replacement? Or i should just stay with this....
