1Wolf
- Jul 10, 2007
I have just built a system with a Samsung 256GB SSD and a Seagate HDD. I'm not using a RAID. My motherboard is an ASUS P8Z77-V Deluxe and i've got the SATA ports in AHCI mode in the BIOS. I do have a "Hot Swap Bay" in my case that is empty at the moment, but eventually I'll probably plug a drive in there once ina while.
After I installed my chipset drivers, I downloaded and installed thie Intel Rapid Storage Technology driver. This seems to load a "Delayed Start" icon in my notification area, and runs a service.
This runs each time I start windows.
Can I uninstall Intel Rapid Storage Technology (or if I shouldn't uninstall it, should I disable it?). I've read the help file documentation and it doesn't really tell me. I've been searching here on [H] and doing some googling and I can't seem to find a straight and reliable answer on this. Some folks seem to say to leave it running and that it does something important. Others say that you dont' need it if you're not running a RAID.
