if its under warranty, you should RMA immediately. Of all the components in a computer, you dont wanna mess with the power supply.
My 600w coolermaster used to do the same thing. I thought it was dying.. It was actually the fan dying. I took out the horriblenoisyannoyingbadairlfow fan and put in a nice zalman one. Problem solved!
Swapping out the fan will void the warranty, though![]()
