i was cleaning my comp with compressed air and when i was cleaning my hs for my chipset i saw some water come out. everything is running fine right now, should i be worried?
There may be some chemistry god that can technically explain away what you saw, but this is it basically. Compressed air that is used for cleaning computer parts will drop in temperature when it escapes the canister, due to lower pressure outside. This causes the compressed air to condense very quickly upon hitting room temperature air, and this creating the "water" you described. I would say it's best to do this after the system is unplugged, you can create a short if you're not careful.
