Hi all,
My setup:
ASUS P8Z68-V-PRO: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131730
i7-2600K, 16GB RAM
2x EVGA GTX 580 1.5GB: http://www.newegg.com/Product/Product.aspx?Item=N82E16814130731
I'm currently running a single 1920x1200 in SLI with the two cards. I'm about to switch to a 3-monitor with each at 1920x1080 setup. I've used the two cards this way before, but have gotten used to the high settings I can use in SLI mode, that two cards just can't handle with 3 monitors.
Is stepping up to a third card a good idea in this situation, or should I be considering something else altogether? I've even considered picking up a used one to save some cash.
Thanks,
Ben
My setup:
i7-2600K, 16GB RAM
Thanks,
Ben
