BackStabber
- Sep 22, 2002
I have put alot of work into my case wiring and sleeving. the case is all uv reactive inside came out great. one problem shotty case fans. I baught a 120mm and a 92 mm green uv reactve fans from svc one for cpu and one for rear exhaust. Bothe fans cracked across the fan blade one completley blew apart. I have never seen this before but there are not many choices in Uv fans for 92mm and 120mm and I would like just uv no LED's I have checked the egg, nextfan, svc, 1coolpc. Any one have any other ideas where to find high output uv reactive fans or other ideas
case is a aopen 650B Thanks
