I was doing some maintenance on my katana (sword) and had some inspiration with the stuff I polish it with...
The stuff leaves an oil residue though in order to keep your blade from rusting while sheathed, so I had to clean it off with some alcohol. The results were great though.
I was able to polish out all the machine marks/grooves out of the finish without resorting to 1500/200 grit sandpaper...
