Share Wifi w/ Gigabit Switch
travm
will this work?
I have very slow internet, so I want to network my PC's together on a wired LAN thru an unmanged switch, and then use a wifi adapter in 1 pc to bridge that connection through the swtich. Is this possible?
Objective being my home network works more reliably and faster (file transfer mainly), while maintaining a stable low latency connection to the internet. My internet is through a company where I have a DSL Modem/Router/Voip device that i cannot twiddle settings on,l
travm
Why would you want to do it this way--you should simply wire them directly to the switch and then to the dsl router.
Because that isn't practical. Dsl router is 3 floors away
Also I've tried AC wireless and it was not satisfactory for file transfers.
cjcox
It's possible, but likely using a separate wifi access point which is connected also via one of those hard wires.
travm
what was your file transfer speed? what speed are you looking to get?
It was slow. Don't recall the exact numbers. Currently when I need to transfer files I disconnect from the wifi and connect two PC's together with an old router. Using gigabit wires is the best solution.
The PC's are so far from the router and comparitively close together, so wifi doesn't hit even rated thoroughput.
GotNoRice
Wired is the best regardless. If you can't wire ethernet all the way to your router, then you should explore MoCA adapters (uses Coax aka Cable-TV/Satellite cable that may already be installed in your home).
If you really want to use WiFi, I would get an actual WiFi bridge instead of using a computer. A WiFi bridge is a self-contained WiFi client device that will connect to your WiFi network and then have an Ethernet port that you can plug into your switch. That way your network connectivity isn't dependent on ghetto software bridge settings on one of your PCs.
To be clear, MoCA is only compatible with cable-TV or dark coax. It cannot be used over the same coax as satellite-TV (the signal frequencies used conflict).
Powerline networking is another possible option, but generally ranks behind MoCA. Still probably better than trying to get WiFi to work well across multiple floors.
travm
The wifi internet is fine, all 5mbps. It's moving 100s of GB from one of to another less than 2 ft from each other that is the problem.
mvmiller12
I take it the problem is that neither of your computers is wired to the internet router?
If BOTH computers are using WiFi AND BOTH computers are running any version of Windows 8 or newer: Just connect the dumb switch between them, and set a manual 192.168.x.x IP on each WIRED adapter in Windows. MAKE SURE THE WIRED CONNECTION IS A DIFFERENT SUBNET FROM YOUR INTERNET/WIFI IP RANGE. Set each computer's DNS/Gateway to the IP of the opposite WIRED computer. Windows will automatically use the faster Ethernet connection for data transfers between the two computers and connect to the WiFi for Internet.
I've done this for a 10G Ethernet connection between my workstation and desktop PC (well, without the WiFi - each computer had a 1G onboard NIC and a 10G PCIe NIC, and the Internet for each machine was over the slower 1G ethernet). I was moving files across between each machine at ~500 MB/s as opposed to the ~100 with just the 1G.
Edit: File transfers were between NVMe SSD on my workstation (System 1 in my sig) and 8x8TB hardware RAID 6 on my file server (a Dell R515 that was rescued from being dumped by a local business doing upgrades, sans drives of course)
travm
Could I take this a step further and use a crossover cable to connect the two PC's together? I haven't thought about doing that in twenty years...
mvmiller12
Most modern NICs don't even require a crossover - you just plug in a regular Ethernet cable and it just works. My 10G cards were connected directly card-to-card that way.
