edward78
- Aug 21, 2011
Where do you find then? The case has one that comes with it, but incase I ever need to replace it I am asking.
The FSP 300 from newegg does not have a PCIE connector. I recently bought one and opened it up. Out of the 2 pads on the PSU pcb, the 4 pin cpu power is connected to 12v2 and all the others are wired to 12v1. Even if you used a molex to pcie adapter, you would be powering the drives, motherboard and videocard from 1 rail while the 4 pin cpu gets a rail to itself. Quite an imbalance.
It doesn't work anymore after I put it back together (my first time out of dozens). IMO, its junk that is badly soldered together. Sloppy construction and blobs of solder everywhere. Go for a Seasonic model.
You are right. Looks as if their own versions don't come with the PCIe.
I also see 80Plus Bronze 400W and 450W on their site (but AFAIK only Silverstone sells their 450W), but they have a disturbing trend of not putting the combined +12v. Also irritating that they are now calling these "micro ATX" instead of "SFX."
http://www.fspgroupusa.com/rank-by-series-micro-atx-series/c/106_218_320.html
