Hey,
I want to build a new mobile mITX dev workstation. I am actively trying to remove laptops from my life since I pretty much only use mine docked anyway
1. What will you be doing with this PC? Gaming, Photoshop (or other intensive programs), Web browsing, strictly HTPC/Playback, etc. (If you have multiple things you want to do with the system, make sure you rank them from most important to least important).
I will be doing all sorts of development. I mostly do Android and some server development. I need lots of ram for emulators, VMs, containers etc. I might do some light Photoshop work for assets. I also want as many cores and threads as possible. Also, I want m.2 storage. I really only need one 256GB disk.
2. Will you be overclocking? (If so, are you looking to watercool?)
No. I am interested in water cooling though. Probably and AIO system. I mainly want silent and cool operation. The box will probably run close to 24/7.
3. What's your budget? Are tax and shipping included in this budget? Is your budget flexible? Is cost a driving factor in component selection?
My budget is flexible. I primarily want the best value and will spend more to get it if need be. < $1500.
4. Where do you live? Do you have any big B&M (brick and mortar) computer chains nearby (e.g. Microcenter, Fry's, etc)?
Bay Area, CA.
5. What exact parts do you need for that budget? CPU, RAM, case, etc. The word "Everything" is not a valid answer. Please list out all the parts you'll need (especially if you will need 3.5" hard drives or expansion cards as these may restrict case options).
CPU, RAM, m.2 SSD, MOBO w/ Graphics, Case, Power Supply. Everything except for a monitor and k/b mouse.
6. If reusing any parts, what parts will you be reusing? Please be especially specific about the power supply. For reused parts, list brands, model #s, and, if applicable, firmware revisions.
I have a Dell U3014 1600p 30 inch it will be hooked up to most of the time.
7. What specific features do you need in a motherboard? RAID? Thunderbolt? Crossfire or SLI support? How many USB 3.0 and SATA 6Gb/s? etc. Which is more important, size of the system or having the particular feature? Make sure you indicate *required* vs. *wanted* for each feature you list.
I would like to have the new USB Type C ports. I really don't need anything but an m.2 drive so SATA is a non issue but nice to have.
8. What resolution output do you need? 4k playback, 1080p playback, etc for HTPC or give a vertical/horizontal resolution for gaming SFF rigs. Do you need multiple monitor output?
It should be able to output up to 4k at 60hz. Movies should be streamable but I won't be streaming. I want to no GUI lag.
9. Does this system need to fit into a particular space and do you need an optical drive? Think entertainment center shelves, closet space, rackmount, etc. Many modern SFF cases have either removed the optical drive or have been constructed so that removing the ODD increases the configuration possibilities immensely.
It will be on a desk. I want the system to be as small and portable as possible. I don't need an optical drive. Front facing usb ports would be nice.
10. How comfortable are you with custom case design/modification and electrical wiring? What tools do you have (Screwdrivers/Leatherman, Drill, Dremel, Metal snips, Soldering Iron, Bending Brake, CNC/Welding machines/Plasma cutter, etc...)?
I just want something I can put together without much extra work.
11. How important is the noise/silence of this sytem? HTPCs typically want to be quiet while all-out SFF gaming rigs don't care
I prefer it be dead quiet.
12. How mobile does this system need to be? Need a carrying handle or carrying straps? Is weight important (carry-on bag, etc)? Water cooling quick disconnects, etc?
As small and as mobile as possible. I want to replace my laptop. I will probably buy a portable USB screen for it eventually.
13. Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? Is it 32bit or 64bit? Remember that OEM copies of Win7 have issues with new motherboards
I will only be running Linux. Probably Arch or something else Debian based. Definitely not Ubuntu.
14. When do you plan on building/buying the PC? Immediately, in a couple weeks, 3-5 years?
ASAP, but I would wait for Skylake if that makes sense. I don't care if it's Haswell if Ivy/Sandy is a better deal. I don't know anything about AMD but if it's a good deal I will go with that.
Bay Area, CA.
