Majeztik12
- Jun 8, 2004
Hey, I was looking into building a SFF unit able to use a normal size ATX p/s. Any suggestions? I know Cooler Masters has some cases, but will the take a normal p/s???
ShaolinDragon said:Majeztik, rephrase your question please, I cant help you if I dont understand what you want.
Soldier Prime said:actually it would take the normal atx power supply. it just wouldn't fit in the case, but the connecters are the same hence mATX and ATX. Now the ATX psu wouldn't fit on an AT mobo.
