SFF microatx case like Alienware x51 or Silverstone LC02
virus3478
Sorry for the long post, TL;DR at the end.
I read through about a million threads on various other forums before breaking down and creating an account. So, first post, new to this forum, sorry if I'm breaking any procedures (I at least read the sticky).
I have been buying pc parts around christmas for the past 4 years. Originally, I put together a low-budget AMD APU, then added a $100 GTX 460 down the road.
Last year I upgraded to an i5-3570, and the AMD got moved to the living room as an htpc in an extra case I found. This year it's time to upgrade my GPU (hopefully to a gtx 770), and I'd like to pass the old GPU down to the living room htpc.
What I'm looking for is (relatively) simple - a SFF case that has 2 full-height expansion (pci/pcie) slots. I want the case to be as small as possible, so preferably something like the two cases mentioned in the title.
The idea is to reuse the micro atx motherboard, CPU (APU), and GPU. I prefer the case to take a standardized power supply (flex-atx, atx, etc.) rather than having an external power brick (hard to find too many 300w+ power bricks..). Some case ideas that appealed to me were:
--NFC S3 chassis (still pre-production)
--A 2U, 3-slot case I found on aliexpress ($60 + !! $170 shipping !! too expensive)
--Silverstone LC02 (out of production for a long time...unavailable everywhere
--Alienware x51 (mini-itx only, and no rear io panel slot; also hard to find case and psu for sale, and expensive)
I've been searching for a few months and haven't found anything. I really want to stay away from the cube-style cases...I just don't like the style. Worst case scenario, I'll reuse my Thermaltake Dokker case (which is enormous, but free nonetheless).
Any Suggestions?!
Technicalities:
1. What will you be doing with this PC? HTPC
2. Will you be overclocking? No
3. What's your budget? ~$100, give or take
4. Where do you live? Do you have any big B&M (brick and mortar) computer chains nearby (e.g. Microcenter, Fry's, etc)? North-Central FL
5. What exact parts do you need for that budget? Case (and psu?)
6. If reusing any parts, what parts will you be reusing? Gigabyte a75m-ud2h motherboard, amd a8-3850, gtx 460, ram, etc.
7. What specific features do you need in a motherboard? RAID? Thunderbolt? Crossfire or SLI support? How many USB 3.0 and SATA 6Gb/s? etc. Which is more important, size of the system or having the particular feature? n/a
8. What resolution output do you need? 4k playback, 1080p playback, etc for HTPC or give a vertical/horizontal resolution for gaming SFF rigs. Do you need multiple monitor output? n/a
9. Does this system need to fit into a particular space and do you need an optical drive?
10. How comfortable are you with custom case design/modification and electrical wiring? What tools do you have (Screwdrivers/Leatherman, Drill, Dremel, Metal snips, Soldering Iron, Bending Brake, CNC/Welding machines/Plasma cutter, etc...)? Very little
11. How important is the noise/silence of this sytem? n/a
12. How mobile does this system need to be? Need a carrying handle or carrying straps? Is weight important (carry-on bag, etc)? Water cooling quick disconnects, etc? n/a
13. Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? Is it 32bit or 64bit? Yes
14. When do you plan on building/buying the PC? Immediately, in a couple weeks, 3-5 years? Before christmas
TL;DR - any cases similar to Silverstone LC02 or Alienware x51 that fit a micro atx motherboard and 2-slot gtx 460?
Wow, thanks for the quick reply! I would like to politely disagree, however:
The silverstone LC02 case takes a microatx motherboard.
The 2u case that I found takes a microatx motherboard:
http://www.aliexpress.com/store/pro...TX-M-B-with-6-PCI-slots/908909_501419596.html
Also, the bixfenix case that you linked to is the "cube-style" case that I'm specifically trying to avoid :\
Really, the LC02 would be perfect, I just can't find it for the life of me! Any clones or something like that?
You are going to have to find some obscure server style case as nothing is mass produced as to what you are looking for. Even the LC02 didn't support pci express cards which defeats the purpose of the case in the first place. I hope to be proven wrong though!
This InWin case is about as small as mATX gets and still supports a decent size video card. I built a friends computer in one, and its an ok case. It does need a bit of modification to get decent video card cooling. I cut a hole in the side panel and covered it in mesh for better airflow. For the mesh, I got some gutter screen at Home Depot and painted it black. Works decently.
InWin BK644
InWin BK633
Honestly, I am suprised I have never seen these cases talked about here in the SFF forums. Its pretty dang small for a mATX. Smaller than a lot of ITX cases. It comes in at just over 14 liters in volume.
I guess its not [H] enough for this forum, because you would have difficulty water cooling it or stuffing in a giant air cooler. however, most smaller top down air coolers should fit. And if you have a hacksaw or a dremel, its easy enough to improve the video card cooling.
It will fit a 10" video card with no modification. 11 1/4" with some case modification.
It takes SFX power supplies
EDIT: more info and correct grammar.
He stated he hates shoebox designs.
Neither is shoe box. The SG10 is a micro tower unit like the X51 is and the Grandia's are all HTPC desktop units (extra wide, very short) like the nMediaPC case, but better quality and the nMediaPC case really doesn't save space. The problem is Silverstone "classical" LC series no longer has an mATX option, these are the ones that look like old stereo systems (80's/90's). But the Grandia series which mimics current day media center components (would look at home next to Xbone or PS4) does. The lack of Grandia inclusion baffles me since its the closest cases as the one he desired, made by the same manufacturer.
