aliensRreal
- Jan 22, 2007
Please note that this was copied off of another forum where little help was received and has only had a quick run through. If things need to be more clear please let me know.
I started having a few problems after I flashed the BIOS. After a few hours the problems seemed to work themselves out and things were ok (it has now been a few days since my flash.) Now, I did a complete turn around. The computer seems to run for not even a half an hour each time it boots to windows. There seems to be no problems when I am in BIOS looking around. So, should I re flash the BIOS with the original or could the BIOS not be the problem? Also if I were to reflash all I have to do is burn the BIOS to a disk and boot to it correct?
(I reinstalled Windows soon after this was initially posted on another forum)
After the BIOS Flash and the CMOS reset the computer struggled severely to turn on. I moved some cables around, un plugged, plugged them back in and the computer turned on no problem.
Later that day the computer just shut down out of no where. I had just turn it on and I believe I was starting AIM up.
After that incident things went fairly smoothly for a day or two. Now I was just playing Half Life 2 for about an hour and a half. The computer froze and I was forced to hit the reset button. After coming back up from the reboot not 20 minutes into the windows session the computer froze again. Tried it once more and sure enough same thing.
E6400 Core 2 Duo
250 gig WD SATA HDD
2 gigs RAM
EVGA 7600GT
Gigabyte 965p-DS3
To add some more information:
I re flashed BIOS to stock and it happened again. What are my options here? Could it be my PSU, CPU, RAM? I ran MEMtest last night and the computer froze somewhere around 20 minutes into the test. After rebooting I ran a CPU stress test and things were perfectly fine. I decided to give another go at the RAM test and found something like MEMtest+ that is booted from CD and run that way. Thus far in the scan it seems no problems have come up.
(This was on Sunday)
From what I understand if it were my BIOS, wouldn't the computer not boot?
Does anyone know what it could be?
E6400 Core 2 Duo
250 gig WD SATA HDD
2 gigs RAM
EVGA 7600GT
Gigabyte 965p-DS3
