Wheresatom
- Mar 20, 2007
I blame all of you, I really do.
I had planned on upgrading to Vista in the next couple weeks. Maybe less than one really. I have several questions, that could be divided up between several subforums, but I was kinda hoping to knock as many of them out here, being you lot are the reason why I have moved up the timetable for my upgrade anyway.
So, I built my computer about a year ago, and I am wondering what hardware I have on my computer right now, that might not be Vista Compatible. I think I have gone down the list of obvious ones, video card, keyboard, and mouse. My problem comes when I get to my wireless card.
Currently my OS is XP 64 bit, and to be honest I don't know that this hardware is overly compatible with that, but it works with the built in Windows manager. The factory drivers install, but none of the features of it work, including that bothersome "connect to a wireless network" feature. Does anyone know if Vista is going to have a similar built in solution that works with this adapter, or should I go ahead and get a new one before switching?
Another issue I would like to check on is pictured below. I asked a question a few months ago about it, and everything I was able to do was inconclusive. I do not remember changing any settings to make the My Computer menu look like it does, but I can't get it to restore either. By look like it does, I mean the lack of toolbars across the top. Luckily my mouse has a back button, so I can manage in the menus right now, but without that, I would be screwed. sfc/scannow didn't fix anything. Basically, I am asking if a total system swap from XP to Vista might change this, with a fresh start. Or, alternatively, should I be doing what I can to fix this before the changeover?
On that note, I would like any odd advice people might have about reformatting. My plan is to get a wired keyboard/mouse from work the day I do it, and have as many drivers as possible, and install files on my flash drive. This way I can just install them without having to download them. Is there anything I am leaving out? I have the little bit of data I need backed up already, although I might do a little update before i bite the bullet.
Folding Questions
One reason why I am changing to Vista is to avoid network instability throwing errors in my SMP client. From what I gather Vista insulates the SMP from these problems, so this should be a good solution to that. If not, I am not opposed to running a VM for my SMP. Is there anything special I should do to prepare myself for possibly doing this in the future?
I have a 80 gig hard drive right now. I don't do anything really with movies, or even pictures on my computer right now, but I might start playing more games soon. I notice this hard drive filling up recently, but I am wondering if much of it has to do with work units and the like. I can only imagine it does. Is the 80 going to be enough to handle Vista 64 bit and much else? Once I add office, anti virus, drivers, firefox, SMP client, etc. am I going to have much room for anything else? I have no idea how much room Vista takes.
Ok, sorry this is long. I have been bouncing this stuff around in my head for a while, and I figured you are all quite helpful, so you might be able to ease the burden of my wonderings.
Folding Questions
