I recentlly assembled new P5W + E6600 based PC, and I have several questions about some issues.
First of all, I have troubles enabling AHCI mode for my 320GB Barracuda disks (oneconnected to red port, other to black (SATA1 and SATA3). I have tried several different options, and all of them resulted in BSOD one second after Windows loading screen. I enabled AHCI in BIOS, and then started Windows XP Pro SP2 installation, and pressed F6 (I used drivers from P5W DH cd on floppy). After installation was over, Windows showed BSOD on first boot. I disabled AHCI in BIOS and I could boot into Windows normally, but every time I tried to change BIOS option back to AHCI BSOD showed again.
Then I tried, again with AHCI enabled in BIOS, to install Windows XP Pro SP2 version with SATA drivers included. On F6 routine it asked me to choose if I want to upload newer drivers (ones that are on floppy), or leave those included in installation (older, but recommended by Windows installation). I tried both options, but both resulted in BSOD one second after Windows loading screen showed.
I downloaded drivers from intel website, and tried to use them instead, in case those found on P5W DH were somehow corrupted. Again, BSOD.
I haven't tried Windows installation without enabling AHCI in BIOS first, but I thought there's no point, as I understandAHCI should be set prior to Win installation procedure. I also haven't tried to install Win with AHCI disabled in BIOS and without F6 procedure, and updating driver from Windows (in Device manager).
What could be the problem. Should I go for one of the options I still haven't tried, or is there something else I'm doing wrong?
Second, I have Super Talent CL5 800Mhz memory, and at the moment I'm running processor on stock speed (2.4Ghz). Should I set memory at 800Mhz, and thus not have 1:1 ratio, or it would be better to run memory in 1:1 ratio, but on lower frequency. What would be the best settngs for 800Mhz memory and E6600 on 2.4Ghz (I'm not OCing it yet).
And third, I have 30-33C idle temps (measured with Core Temp), and 50-55 on load (15 minutes of Orthos for example). Everest shows same temps, while bios shows 23-25,up to 30 idle, and 40-45 load. Are those temps good enough for E6600@2.4Ghz? (I'm running Freezer 7 Pro with Q Fan disabled, thus on 2500rpm fan speed, and my case is open at the moment, with 12cm front and 12cm rear fans. I know those temps are good (I never had processor with those kind of temps), but I'm asking this because on Freezer installation, I had to remove and reseat it again, so part of thermal compound stayed on HSF and part on CPU. Should I bother with taking Freezer off, cleaning the thermal paste, and re-applying the Artic Ceramique and Freezer again, or my temps are just fine?
Btw. E6600 is week 31A.
