Hey guys so I have a gigabyte e45-ud3p and an intel q6600 quad SLACR. I need some help with overclocking on the unit. I am on Phase change for the CPU cooling wise. With 2 spot cools over the NB and the RAM. I have a bench table, so everything is open air cooling also. I posted in the gigabyte thread but its so busy i dont know if many people see my questions
My Questions:
What are the safe voltage areas for my particular setup? Am I safe where I am at now? Can i go higher in some areas?(See Log of Settings)
What are some settings I can try for my memory. I dont quite understand the ratios anymore and Im not sure if the few attempts ive had BSOD because ive set memory to high or something. I have GSKILL F2-8500CL5D-4GBPI PC2-8500 5-5-5-15 2.1.
Is there anything you can see in my settings that I should change?
My Questions:
The settings:
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ..............: [A]
CPU Clock Ratio ......................: [9X]
x Fine CPU Clock Ratio................: +0.0
CPU Frequency ........................: 4.05GHz( 450x9)
********** Clock Chip Control ********
>>>>> Standard Clock Control
CPU Host Clock Control................: [Enabled]
x CPU Host Frequency(Mhz).............: [450]
PCI Express Frequency(Mhz)............: [100]
C.I.A.2...............................: [Disabled]
>>>>> Advanced Clock Control..........: [Press Enter]
CPU Clock Drive.......................: [800mV]
PCI Express Clock Drive...............: [900mV]
CPU Clock Skew........................: [ 0ps]
MCH Clock Skew........................: [ 0ps]
******** DRAM Performance Control ********
Performance Enhance...................: [Standard]
Extreme Memory Profile(X.M.P.)........: [Disabled]
(G)MCH Frequency Latch................: 333
System Memory Multiplier (SPD)........: [2.00C]
Memory Frequency(Mhz).................: 1080
DRAM Timing Selectable (SPD)..........: [Auto]
****** Motherboard Voltage Control ******
Voltage Types..........Normal...........Current
>>> CPU
Load-Line Calibration.................: [Enabled]
CPU Vcore..............1.27500V.......: [1.5]
CPU Termination........1.200V.........: [1.38]
CPU PLL................1.500V.........: [1.61]
CPU Reference..........0.760V.........: [.914]
>>> MCH/ICH
MCH Core...............1.100V.........: [1.4]
MCH Reference..........0.760V.........: [.914]
MCH/DRAM Reference.....0.900V.........: default
ICH I/O................1.500V.........: [1.570V]
ICH Core...............1.100V.........: [1.200V]
>>> DRAM
DRAM Voltage...........1.800V.........: [2.18V]
Everything else auto or default
